I am having hp nx6110 laptop and it gives me error msg as soon as w desktop is loaded "power surge on hub port" and after 10 minutes laptop hangs
I have a problem with msg error that say Power surge on a hub. I cannot print because of the hub ports
OK if you have anything plugged into the USB Ports at bootup, unless Keyboard or Mouse, remove everything, and see if it boots normally, if it does, then the "Hub" you are using may be faulty, or a device you are using is drawing a lot of current at switch on and overloading the USB bus, that can only supply 500mA. If it still does it, and you do use a USB KB & Mouse, then remove them one at a time & reboot, between, and see if it was one of them causing the problem. If you have nothing attached then your internal USB bus is flaky.
