20 Most Recent HP Compaq nc6120 Notebook Questions & Answers
Download correct driver from www.hp.com/support and install
HP Compaq nc6120... | Answered on May 28, 2016
please post this in English
HP Compaq nc6120... | Answered on May 06, 2014
The Spoolsv.exe executable file is responsible for handling the printing process on a Microsoft Windows system. Although this process is not crucial to run your Windows system, you must not terminate it until you think that it is causing problems on the system.
To fix spoolsv.exe application error, you will have to remove these files from the system. To do this, perform the following steps on your Windows XP computer:
  1. Open Control Panel, select Performance and Maintenance, select Administrative Tools and then select the Services option.
  2. In the Services management console, locate the Spooler services, right-click on it and select Stop.
  3. Next, open the C:\Windows\System32\Spool\Printers folder. (Here, we are assuming that your Windows is installed in the default C:\Windows folder)
  4. Delete all the .SHD and SPL files from this folder.
  5. Next, open the TMP folder and delete all old and unused files from this folder.
  6. Finally, restart the Spooler service from the Services management console.
    Note: If you are unable to delete the files in Normal Mode, then you may have to restart your computer in Safe Mode to delete the files. To start your PC in Safe Mode, press F8 at system restart and then select the Safe Mode option from Windows Advanced Options Menu.
    If deleting the files does not rectify the problem, you must perform a System Restore and rollback your system to the time prior to when the error started appearing on your computer.
  • It is important for you to know that application errors can also occur due to virus or spyware infections. In fact the Spoolsv.exe process is also a known backdoor vulnerability that can be planted on your computer for malicious purposes by a hacker.
*Your vote is highly be appreciated. Thanks in advance. Let me know if this fix your problem.
Best regards
HP Compaq nc6120... | Answered on Apr 19, 2014
Type in the password otherwise, if you don't know it, ask the owner of the machine for the password.
HP Compaq nc6120... | Answered on Apr 12, 2014
you should uninstall wifi driver and then install. It will workhopefully.
HP Compaq nc6120... | Answered on Jan 31, 2014
Uninstall the Easy Drive Lock Driver.
HP Compaq nc6120... | Answered on Jan 25, 2014
change le hard disk c la seulle solution
HP Compaq nc6120... | Answered on Jan 09, 2014
change le hard disk
Mostly laptop boots slow issue occurs due to broken Windows registry entries. Fixing registry will help you to boost up your laptop. You need to download and install a Registry Cleaner program to fix corrupt or broken registry entries. To download a reliable registry cleaner, go to famous website download.cnet and search there Reginout. Which I personally use and recommend the friends. After downloading run all of its tools one by one except Internet Optimizer, to clean all the junks and registry errors from your computer.
HP Compaq nc6120... | Answered on Dec 02, 2013
u need to download and install its device driver to used it. go to my computer right click and choose properties, then go to hardware and select device manager and you will all uninstall driver with ? mark. means u need to install it.... go to www.hp.com - support - driver put your loptop model and download all appropriate driver in there and install it... just click the exe, its automatic
HP Compaq nc6120... | Answered on Nov 11, 2013
actually , the problem
with cable for Display or VGA ship-set
problem , you have plug you laptop with external
Screen then check , if still " Vibrating "
check the driver for VGA , is it correct , if there is no problem with vga driver it means ,VGA ship-set problem
hope help you
BR
Mohamed Hejazi
HP Tech. Support
HP Compaq nc6120... | Answered on Nov 10, 2013
Whats the question?
HP Compaq nc6120... | Answered on Sep 09, 2013
HP Compaq nc6120 Notebook Logo
219 questions posted
Top HP Computers & Internet Experts
Thomas F. Schneider
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • HP Computers & Internet
Most Popular Question
hp compaq nc6 120 model laptop but dont
  • Computers & Internet
