20 Most Recent HP Compaq nx6110 PC Laptop Questions & Answers
Compaq nx6110 no clock setting in bios
Compaq nx6110 no clock I presume you meant. the DATE IS WRONG and if changed in BIOS to correct as all can do. it will not safe that means the RTC CMOS coin cell battery is now dead as most are at 7 year old. the cure is replace with a new one, spend a buck. RTC is chip called REAL time CLOCK, just like a wrist watch in fact. and like that watch dies with the battery dead. a 2005 PC, so is 10 years old in 2015 and is the high water mark on super good life span. means DUE NOW.
4/14/2022 12:33:03 PM • HP Compaq nx6110... • Answered on Apr 14, 2022
My asus a6000 doesn't seem to notice it's internal speakers
Well I, generally reboot my comp when this stuff goes wack. I'm guessing you tried that. Also, let it stay off for a while. Try reinstalling the driver, updating the driver, and/or downloading a new one. Please rate, if I was helpful.
9/12/2019 1:52:55 PM • HP Compaq nx6110... • Answered on Sep 12, 2019
Samsung hdtv to compaq pc
There should be a setting within the comp. Is it connected to the comp monitor and the tv? Perhaps from the comp to the tv with the monitor from the comp as well? Well if so, you may need a certain setting within the comp. Check under (on xp) display properties, and then under the settings tab. Please rate!
9/12/2019 1:51:30 PM • HP Compaq nx6110... • Answered on Sep 12, 2019
I want hp nx6110 ethernet
You can download all driver for HP Compaq NX6110 PC Laptop. http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=449878&prodTypeId=321957&prodSeriesId=449877&swLang=8&taskId=135&swEnvOID=1098
Open this link and go to
Driver - Network
Broadcom BCM440x 10/100 Ethernet Driver for Microsoft Windows XP 1.01 A
2 Feb 2005 24.7 56K: 1h
512K: 6m
2 Feb 2005 24.4 56K: 59m
512K: 6m
and download both and then install on your laptop.
I hope it will resolve your problem.
Enjoy
7/17/2019 11:22:45 AM • HP Compaq nx6110... • Answered on Jul 17, 2019
When I turn my laptop on it say, PRESS THE ESC KEY
if you have nothing wrong with the laptop and it start up normally , do nothing it may have moved to a notice that will go after a few seconds (10)and then proceed to normal start up if it doesn.t then on pressing the start button hold down the delete key and eventually the bios menu ( start up menu) will come up on the screen you van make changes to the start up procedures her but be very careful as any changes may get you into bigger trouble that what you have now if you get the lap top running normally( not touching the bios settings ) press icon in the bottom lh of the task bar( flag in the world ) and that brings up the programs at the bottom of that list is a search bar type in chkdsk and then enter and puts the laptop into a check of the disk operation that operation will find , fix and place the registars in all of the correct positions for all programs , files , folders , photos etc on the disc and will take up to 6 hours to complete if the disc is operating correctly If you have a mechanical problem with the disc , you will get that message and the only fix is a new hard drive
11/10/2017 12:13:04 AM • HP Compaq nx6110... • Answered on Nov 10, 2017
My laptop is locked in the docking station and I
ouch why not ask , HP,? the real maker,? we are not HP , at all, not in the least... https://h30434.www3.hp.com/ most of this is legacy harware, and books are gone and persons using it , gone or long forgotten. what station, tell them the station service tag part number be first
8/19/2017 1:01:02 PM • HP Compaq nx6110... • Answered on Aug 19, 2017
2answers
Laptop keeps hanging
TRY TO BACK THE OLD ONE IF IT IS OK THE NEW ONE ARE NOT COMPATIBLE
4/16/2016 6:04:47 AM • HP Compaq nx6110... • Answered on Apr 16, 2016
Nx6110 orang led flashing
This is probably meaning the battery is low or at fault.
3/6/2016 4:33:21 AM • HP Compaq nx6110... • Answered on Mar 06, 2016
I need a manual to use with my computer so I know if it still works.
HP Compaq nx6110 Notebook PC Manuals ' HP ...
h10025.www1.hp.com/ewfrf/wc/manualCategory?...
Hewlett?PackardManuals or User Guides for your HP Compaq nx6110 Notebook PC.
HP Compaq nx6110 Notebook PC - Manuals - HP Customer ...
support.hp.com/us-en/product/HP-Compaq...Notebook-PC.../manuals/
Find support contact options like chat, phone or email specific to your HP Compaq nx6110 Notebook PC including Service Locations and Check repair status.
Manuals for HP Compaq nx6110 Notebook PC - HP Support ...
h20000.www2.hp.com/.../DocumentIndex.jsp?...Suppo...
Hewlett?PackardHP Compaq nx6110 Notebook PC. Warranty status only indicates current warranty state. If you have an active Support Agreement or HP Care Pack, you can link ...
[PDF]Maintenance and Service Guide - tim.id.au
1/24/2016 7:52:23 PM • HP Compaq nx6110... • Answered on Jan 24, 2016
3answers
Power-on password forgotten! How can the computer be started?
The Power on Password is set from the BIOS configuration. Ask that person who borrowed your Compaq for the password. Once you have this password, you can enter the BIOS configuration and remove/disable this password.
Depending how old you Compaq is, removing the BIOS battery and main battery for 15+ mins may remove this password and restore the BIOS to the factory default (insert both batteries again) and configure the BIOS Date and Time etc.
BUT if the the password is stored on an EEPROM chip then removing will not fix this problem. There are no backdoor passwords available.
1/5/2015 11:15:09 AM • HP Compaq nx6110... • Answered on Jan 05, 2015
Remove drivelock password
At boot time select DEL or F1 key to get into BIOS. Then advanced settings and Hard Drive password.
9/2/2014 9:51:48 PM • HP Compaq nx6110... • Answered on Sep 02, 2014
2answers
Reset bios password
You need to locate the Cmos battery, not the jumpers, this is not a desktop.
Locate the Cmos battery, disconnect the battery for ten seconds, and Bios will reset to factory default.
7/6/2014 8:34:52 AM • HP Compaq nx6110... • Answered on Jul 06, 2014
What is CrossFire
You can find info for this on the AMD website, basically it is a way of connecting two identical graphics cards to increase power on a desktop PC, but it has also been applied to a couple of laptop models (most noticably, Alienware).
6/27/2014 5:04:56 PM • HP Compaq nx6110... • Answered on Jun 27, 2014
2answers
There are some blue,red,pink and green vertical
Hi
With sorrow, the screen have problems
What recently happened before those lines appear?
You can knock ( softly ) on the back of the screen around the lines, and see what happens
Please tell us your results
Good Luck
6/27/2014 5:00:15 PM • HP Compaq nx6110... • Answered on Jun 27, 2014
List f key funtions
http://www.computerhope.com/issues/ch000306.htm
5/23/2014 2:49:50 PM • HP Compaq nx6110... • Answered on May 23, 2014
My notebook laptop demand for a password at power
change the power setting and also disable the password option
5/23/2014 2:12:42 PM • HP Compaq nx6110... • Answered on May 23, 2014
Which driver is needed to install skype on a HP
no driver is needed to install the skype on any machine
5/23/2014 2:06:41 PM • HP Compaq nx6110... • Answered on May 23, 2014
0answers
HP Compaq nx6110 PC Laptop Logo
443 questions posted
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • HP Computers & Internet
Most Popular Question
driver needed install skype hp
  • Computers & Internet
