Hotpoint Aquarius WF220 Front Load Washer Logo
Posted on Feb 09, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Does not fast spin - Hotpoint Aquarius WF220 Front Load Washer
Gerry Harvey
Level 3:
Genius:
  • Hotpoint Master 1,482 Answers
  • Posted on Feb 09, 2010
Gerry Harvey
Hotpoint Master
Level 3:
Genius:
Answers
1482
Questions
0
Helped
379230
Points
4533
Clean/ check filter...Also could be out of load balance due to insufficient load....
Maytag Bravos MTW6600TQ0 spins exceeding fast on all spin cycles
It’s designed to spin fast on spin cycle but should be some speed difference if there are selections for different speeds. Control board problem most likely
2000 toyota rav4 motor spins over fast but will not start. Weak fire as well
If it spins over fast like there is no resistance at all then you have a bigger issue. Could be dropped valve, timing, warped head, etc. The amount of compressioninside the cylinder will not allow it to spin over freely and fast.
1helpful
What causes the water not to spin out of the clothes?
Hi, it means that the machine is not spinning fast enough and pumping the water away. If its not spinning enough then you have to get the machine looked at as its not clicking on in the cycle for it to spin fast enough. You also have to have it set to wash cycle that has a fast spin. If it is spinning fast then you have to look at the pump to make sure its pumping the water away.
Atf6000fs2 does not fast spin to remove water only slow spin /checked it on all spin speeds
Either the motor cannot turn over fast enough to power the pulley system, or there is an issue with the pulley system.
Gsd2030z02ww arm does not spin fast but does spin some. Motor is spinning fast
The arms don't spin all that fast .. Mine takes about 2 seconds or so to go around once.
2helpful
Whirlpool washer lxr9245eq1 doesn't spin dry completely
Try this... while in in spin turn your spin selector switch and listen if motor spins slower or faster.. at fast spin open your lid quick to see how fast its spinning.. check and make sure your drain line is cleared and the water flow out fast...and if its spinning too slow problem is in the gearbox area..
Kenmore 90 Series washer needs two spins to remove water
We have exact same washer. It is 11 years old. We are at a point where we have to spin it 7 times and then still isn't too dry. It dies yesterday a very loud death. Mentioning this here because it could be a foreshadowing of your Kenmore 90's future.
Printed wash cycle info missing from front of machine
Quick wash cycle for the Hotpoint FEW12 is 'K'
A 95* White cotton, heavy soil ........ 5.5kg 2hours 30/40 mins Fast spin
B 40* White cotton Heavy soil .......5.5kg 1hour 40/50 mins Fast spin
C 95* White cotton and linen without special finishes......5.5kg 2 hours 20/30 mins Fast spin
D 60* Colour fast cotton, linen or viscose without special finishes......5.5kg 2hours 5/15 mins Fast Spin
E 40* Non-colour fast cotton, linen or viscose.....5.5kg 1hour 40/55 mins Fast spin
F 50* Synthetics, coloured nylon, polyester, acrylic & cotton mixtures, cotton or viscose with special finishes, coloured polyester & cotton mixtures.....3kg 1 hour 5/15 mins Slow Spin
G 40* Acrylics and tri-acetate blends of these fabrics with wool, polyester & wool blends....3kg 40/50 mins Slow Spin
H 40* Wool, shrink resistant machine washable wool, woolen blankets..... 1.5 kg 1 hour 15/25 mins Fast Spin
H...(Wool mixtures with cotton or rayon.....2.5 kg)
J 30* Silk, printed acetate.....3kg 55 mins/1 hour 5mins... Slow Spin
K Quick wash for freshening up lightly soiled items. Warning... not for woolen, silk or delicate items.....1kg 35/45 mins Slow Spin
L Cold wash, cold fill only, no heating action....3kg 55mins/1hour 5 mins Slow Spin
M Rinse and Fast Spin... cotton......5.5kg 55 mins/1hour 5mins...Fast Spin
N Rinse and Slow Spin... Delicates....3kg 30mins Slow Spin
P Fast Spin .... cotton.... 5.5kg 15 mins Fast Spin
Q Slow Spin.... delicates.....3kg 15 mins Slow Spin
Hope this helps
Sue
Top Hotpoint Washing Machines Experts
vince
Paul Carew
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
