That is dangerous. Call for service, the law says only registered gas technicians can work on gas appliances. Turn the gas off at the rear. There is enough gas in a dryer leak to blow your windows out on that floor. The igniter or thermocouple is faulty.
Absolutely. Your dryer runs on gas, and the gas kicks on when the heating element engages. It should be so faint though. If you smell it continuously then check your connections with soapy water, if their is a leak then shut off the gas and try using soap pipe dope, or teflon tape on the threads, then recheck. My guess is its the regulator near the heating element. Good luck
If the connection to the back of the dryer is sealed and tested with a mix of water and soap the gas smell is coming from the injector area direceting the gas to the spark sensor. Upon starting the dryer the spark sensor makes a clicking sound that ignites the burner. If no heard the spark ignitor is at fault
The gas valve should not be opening unless the glow igniter glows and sends a signal to the gas valve. I suspect a small leak in either the gas pipe or at the gas valve. You will have to get to the gas valve to perform a leak test. While the dryer is open, replace the igniter.
turn gas off to dryer. For safety it is best not to wait get your gas company to find leak(i don't think they charge for that)if it is at the control valve you should take the screws that hold the coils down out.Remove coils and rubber O rings and replace all with new ones it comes as a kit
If when you run it you smell gas please stop running it! You should shut the gas valve off immediately anyway! If the gas heater isn't working when your running it it's probably the Valve that activates the gas (Selenoid) or the Ingnitor that lights it!
It could be the burner which distributes the gas in which case you would smell gas.
My best guess......the ignitor!
