20 Most Recent
Maytag MDG2706A Gas Dryer Questions & Answers
Drum rotates no heat,igniter dosent start
While the drum is rotating you should hear the
CLICK associated with the gas valve assembly powering up to give out a blast of heat. If ya don't hear no click check the duct fuse. Right next to the control thermostat. If it is blown it kills the circuit to the gas valve assembly. If that fuse is good and the control is also good, then check the flame sensor for continuity, If it is open then the ignitor won't glow. The ignitor must glow and change in resistance then the flame sensor must open up and kill power to the ignitor so that power will be shifted to them coils on the gas valve. If you need further help, reach me via phone at
https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Not heating up
Hi
I
believe that everything else is fine rather it is the thermal fuse that is
located inside the rear panel to the exhaust duct that is bad and should be
replaced. If you want you can test this fuse for continuity and if it is bad
then it should be replaced, as it cannot be reset. If the fuse is fine then it
can be due to the control board that is bad and should be replaced.
Hope this helps...please post back for further assistance.
Daniel
I have a Maytag dryer,model#
If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly.
if you dryer is gas check out this
gas no heat tip....
If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat.
check outthis
electric no heat tip...
heatman101
Heats up for short time then goes cold. Cleaned
gas no heat tip....
check outthis
heatman101;
3 BATH TOWELS AND ONE HAND TOWEL WERE NOT DRY
HI,
If the unit is less than a year, you problem is a restricted vent system and not in the unit either. A simple test would be disconnect the vent from the back of the unit, run the dryer. If your clothes dry faster, your problem is in the vent system. If no improvement, problem is in the dryer. Get back to me and let me know how this goes.
Thanks I’m happy to help further over the phone at
https://www.6ya.com/expert/gere_bf68e6055dd61249
My dryer is not getting
gas no heat tip....
check outthis
heatman101
MY Maytag Gas Dryer SDG515DAWW
Hi
I believe that everything else is fine rather it is the thermostat that is located inside the rear panel to the exhaust duct that is bad and should be replaced. If you want you can test this fuse for continuity and if bad replace it as it cannot be reset. If the fuse is fine then check the dryer belt and idler pulley...Hope this helps...please post back for further assistance.
Daniel
Dryer producues heat for only first five minutes...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Belt mjakes a noise when
Hi
The belt is either bad or worn out, also the idler pulley
should be checked. Hope this helps...please elaborate for further assistance.
Daniel
