20 Most Recent Kenmore 73952 Gas Dryer Questions & Answers
get some windex and clean the sensor strip located behind the filter ousing similar to this picture. Their might be something on it that is interfering with its moisture sensing ability. Check out my youtube channel about section for a link to a free dervice manual for you model. Thanks
Dan Webster
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Kenmore 73952... | Answered on Apr 07, 2018
Raise the control panel and replace the electronic board ( 5" x 7" ) .Came across this same problem tuesday .
Kenmore 73952... | Answered on May 01, 2016
It sounds like the drum is frozen. The squealing is from the motor slipping on the belt. There may also be something keeping the belt from tightning. Try these links:
ShopYourWay
Appliance411 Home Service Appliance Repair Manual for Whirlpool Kenmore...
User Manual Downloads
Kenmore 73952... | Answered on Feb 06, 2016
The drive belt is broken and will need to be replaced.
Kenmore 73952... | Answered on Dec 29, 2015
Try vacuuming lint and dust out of the burner intake and exhaust ports. Hope this helps!
Kenmore 73952... | Answered on Nov 12, 2015
is it heating as good as you think it should . quite possibly the problem is with the washer not spinning them as dry as it is supposed to .there fore making the dryer seem the problem
Kenmore 73952... | Answered on Apr 08, 2015
LOCATED ON THE BLOWER NEXT TO THE CYCLING THERMOSTAT
Kenmore 73952... | Answered on Mar 31, 2015
The dryer sheets soften during the drying cycle to release the softening material. Air flow through the dryer drum causes the sheets to "glue" themselves to the vent outlet. If you have the dryer disassembled for service, you will find a sticky residue on the back of the vent.
Kenmore 73952... | Answered on Dec 31, 2014
Hello Bob;
My name is Peter. I am a retired field service appliance technician.
I assume you are not referring to the lint filter on the top of your dryer.
Behind your dryer is a elongated hot air distribution manifold. Looking from the back of your dryer it is on the left. The manifold is fixed to the back of the dryer with screws. Unscrew the screws and remove the cover.
In the bottom of this manifold is where air flow blockage occurs. Clean this inlet out.
At this location you will not be exposed to any electrical or moving parts.
Cleaning this outlet will enhance the dryer air flow and dryer performance.
Kenmore 73952... | Answered on Nov 04, 2014
This is very likely a relay problem. There is a black relay in the control head that engages when the start button is pressed. The relays tend to go bad now and then. They are a simple replacement and cost less than $15 or so.
Kenmore 73952... | Answered on Oct 04, 2014
Could be your gas valve.
Kenmore 73952... | Answered on Jul 27, 2014
The Thermal Fuse is located on the air blower housing. Its a small white plastic component with two wire leads.
The Thermal Cut-Out (TCO) is located on the outside of the heater box on the end opposite the heating element terminals.
The reason I mention both these components is because some people confuse the two and use the words interchangeably. There is a difference between the two components and what they do.
DOUBLE CHECK YOUR SYMPTOMS:
If your dryer does not run at all, check your Thermal Fuse.
If your dryer runs, but does not heat you need to check the Thermal Cut-Out.
If you have any questions, please post back and let me know what symptoms you are having. Please include your complete model number (located on a nameplate around the door opening) so that I can determine how your dryer is configured. I hope this is helpful to you.
Kenmore 73952... | Answered on Jun 05, 2014
In order for us to provide you accurate information and supply you with the correct manufactures part numbers , we will need the complete model number, serial number and batch or series numbers (if applicable) found on a business card size metal/foil plate. If you are having difficulty locating this identification label, follow this link which will take you to our Website where we have pictures of common locations where your model number ID label can be found. Here is the link: http://www.affordableappliance.com/Tips/modelnumbers.htm Once you have the updated information, please reply to this email. Eric Campion
Kenmore 73952... | Answered on May 22, 2014
Kenmore 73952 Gas Dryer Logo
593 questions posted
Top Kenmore Dryers Experts
Marvin
Marvin
jimorris77
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
View Most Popular
Kenmore Dryers
  • Kenmore Dryers
Most Popular Question
clean lint from model 110 72952100 gas
  • Dryers
