If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
properly.
if
no heat
tip....
heat.
check
out this electric
no heat
tip...
heatman101
properly.
if
no heat
tip....
heat.
check
out this electric
no heat
tip...
heatman101
Hi,There can be many reasons why your dryer will not start or turn...The most common causes are the belt breaking or jumping off, or the motor going bad...Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...Dryer Repair - The Dryer is not TurningDryer Repair - The dryer will not startheatman101
24 questions posted
1,329 Questions
1,410 Questions
750 Questions
524 Questions
182 Questions
