The blue light just flashes. it was glitching for a while then it just flashes is it easy to fix instead of replacing. our dumps dont need another monitor. I guess i would need a diagrahm and a product that i would need. If you can help thank you
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
usually in any type of laptop charger the flashing light is a blown fuse or resister only by taking the device apart and finding the blown part (maybe visible) and either replacing or just soldering over it will do, you could also try getting a bit of copper wire from old phone charger or speakers or even coax ariel and taping it across the part with insolation tape but that is deffo your problem and this is deffo your fix :) good luck
its the on board video card needs to be reworked i do it all the time and for half the price of anyone else i dont like when they say 125.00 to fix it should be like 50.00 thats what i charge its easy to do
your lamp is burned out-easy and fairly cheap fix. Order a new lamp and install it according to the instuctions sent with the lamp.Dont believe that you need to take it to a service to have it fixed, this should be less than $150 fix-good luck
I guess if you don't have the owners manual, you can just keep pulling them out and checking them. Or, the best way is with a test light. Turn your ignition on, ground the test light to the door hinge, and keep touching both sides of the fuse with the test light, until you find one that doesn't light up the light.
Usually this problem is due to the firmware. When the firmware is updated to version 1.62.02, this problem usually will be corrected. The older firmwares have problems in recognizing the battery and allowing the battery to power the unit.
You will need a wall/AC charger for the operation. Plug in the wall charger and USB cable at the same time. Your Zen should power on when connected to direct AC power via the wall charger. Once it is powered on, connect the USB cable to your computer. Then begin the firmware download.
If your Zen does not power on when connected to the wall charger, your unit is dead and its time to replace it or get the motherboard replaced via one of the Repair services offered on this website.
If the upgrade button on the firmware window is not available, it is also time to replace your motherboard due to corruption of a chip on the board.
