I have a Leisure Classic 90, and the digital clock is flashing Auto P0:00, and I can not reset it. This is resulting in my cooker refusing to work? Any suggestions please. I have tried every option available in the manual. Thanks
First I would say to unplug it wait a couple seconds and plug it back in case it got a power surge from the power going . Then reset the clock! Right now it's set in a power saving mode until you do the steps above!
i am sorry for you, but you can forget repairing the timer.
You can replace it of course.
You do not need the timer to operate the oven.
For that you need to bypass the timer. The clock will stay working normally.
Although the 55 is smaller then the 110, the working of the clock should be the same.
Net link will give you more information and I hope you will fin the solution there.
Kind regards and a good weekend, Dik
Try the 6 push buttons under the clock. press in the first two buttons from the left simultaneously and then the - and + to adjust the clock. Thats how it works on my Classic 90 but not certain about the 110
After a power failure most digital clocks have the zero's and auto flashing. These ovens will not work if clock(time of day) is not set. By pressing incorrect buttons, you can complicate things further. Recommend turning off power to oven for a few seconds, then follow manual for resetting clock, which is usually holding down the 2 buttons on the left hand side simultaneously, and holding down these two press the + or - key to advance clock.
Just to let you know that i have solved the problem with my cooker, (clock flashing after electric going off) i held down the cook period button and the end time button, then i was able to reset the clock by pressing the +button.
