20 Most Recent Rangemaster 110 (Dual Fuel) Dual Fuel (Electric and Gas) Kitchen Range Questions & Answers
Hi Andy,
it looks like you are talking about the "wire" that belongs to the thermostat. Follow the wire and you will find that the other end is in the oven. This is not a commom wire, but it is hollow.
the link below shows you what I mean.
I hope this will help you.
Kind regards, Dik
Oven Thermostats Help Advice Fitting
Rangemaster 110... | Answered on Feb 27, 2018
Hi,,
this cooker has 7 burners, one of them is a wokburner.
You can buy complete sets:
http://www.ebay.co.uk/itm/RANGEMASTER-110-Hob-Oven-Jet-Nozzle-Liquid-Propane-Gas-LPG-Conversion-Kit/202177987194?epid=571965912&hash=item2f12bf427a:g:3HYAAOSwoVNZ5yaD
These jets can be changed easily with a 7 mm wrench.
Succes, Dik
Rangemaster 110... | Answered on Feb 17, 2018
Hope this helps with your dual fuel version 3 weeks on and working perfectly! Rangemaster 110. Ovens not lighting due to faulty auto/clock. FIXED! Our clock /timer kept flashing and would not reset
Someone, somewhere on the internet had the solution to my problem but I can't find the link again to thank them! If you don't mind losing the clock/timer auto function this is for you and it's free! Just takes a bit of time.
Basically you need to lift/open up the LH &RH hobs to get at the wires behind the clock. You should see 2 blue(neutral) wires coming directly from the back of the clock. Pull them out and connect together - should be easy to click them together. Then the ovens will light - but you will lose the auto/clock/timer functions. We only used the timer so not a big issue. We didn't take the control panel off but we did take ages to unscrew the hobs etc Probably took us about 2 hours going back to instruction manual we found on internet and trying to work it out but I think we've saved a lot in not replacing the unit with the usual call out charges. We made sure electrical supply was switched off and just took our time. Really chuffed!
Comment by tinling, posted on Nov 06, 2008 http://www.rangemaster.co.uk/Siteimages/Site_311/BigMedia/RM110Gas_04_06.pdf
This should allow you to see the instruction manual for the 110. There was another one somewhere showing a diagram of how to link the 2 blue wires at the back of the clock but I can't find it again! By the way our cooker is 10 years old so maybe different from newer models. We didn't have to take of the front control panel we accessed everything by lifting up the hobs to get behind the clock/timer.
Hope this helps! Ovens still working just got to go and buy a wee timer.
Rangemaster 110... | Answered on Nov 22, 2017
Is there any sort of fan in there - could be some blades hitting surrounding.
Rangemaster 110... | Answered on Sep 14, 2017
at the back of the timer/clock there are 4 wires live and neutral to power the timer/clock and 2 others they may be red or orange. safely connect these other 2 together and you are good to go. if you need a new clock email me info@topoftherangeltd.co.uk
Rangemaster 110... | Answered on Nov 24, 2016
Yes. Use your model number and call a parts supplier, they can help you find the right piece of insulation... Range Stove Oven Insulation WPW10208653
Rangemaster 110... | Answered on May 13, 2016
I know the answer. You ,must set the clock else the oven(s) wont work.
Rangemaster 110... | Answered on Aug 07, 2014
clean the points and check the battery terminals as well as checking the spark plugs and fuel/carburettor and fuel lines.
Rangemaster 110... | Answered on Jun 12, 2014
Rangemaster 110 (Dual Fuel) Dual Fuel (Electric and Gas) Kitchen Range Logo
110 questions posted
Top Rangemaster Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Thomas F. Schneider
Are you a Rangemaster Kitchen Range Expert? Answer questions, earn points and help others
View Most Popular
  • Rangemaster Kitchen Ranges
Most Popular Question
range leisure
  • Kitchen Ranges
