20 Most Recent
Rangemaster Proffessional 110 Gas Kitchen Range Questions & Answers
Some rings work, some don't on hob
Hello both of you,
my first impression will be dirt in the injectors.
I suppose this top has removable injectors. Normally you can remove them with a 7mm socket
As the pressure is really very low in the grid, every single part of dirt in that little hole will block the gasstream.
When I refurbish a cooker, I always clean these thoroughly.
I wish you succes, Dik
My gas over burner light
Hello David,
I am afraid your oven will not be ready for tomorrow.
Now adays all ovens have a FFD (= Flame failure device) also known as FSD (=Flamesafety device), that makes shure that the gassupply is almost shut of when the oven does not burn for some reason.
Often people think it is the thermocouple, but it is not
Yours may be look a little different, but that one needs to be replaced, as repairing it is impossible.
It is connected at the burner
I hope this helps, kind regards, Dik
Timer not working - flashing auto permanently so
Try the 6 push buttons under the clock. press in the first two buttons from the left simultaneously and then the - and + to adjust the clock. Thats how it works on my Classic 90 but not certain about the 110
Griddle burner wont spark
Make certain the burner and burner base are very clean by carefully washing in warm soapy water, using a plastic brush to scrub any residue off the surfaces. Also clean the spark ignition nub in this same way.
Door glass shattered 3 hours after cooking
The problem is that the holding screws that secure the glass in place were most likely OVER TIGHTENED.All the screws around the support holders of the glass have to be tightened just right and the glass can cool off without the pressure that makes it pop.
When I turn on the main oven it lights up but
Yes. If any moisture or food particles get into the ignition area, especially moisture the igniter will continue to ignite and drive you nuts. Be careful when cooking not to do this by layering the rack with aluminum foil to catch any spillage.
Timer
After you set the time ,do you push the Clock button to lock your time??If you set the clock time and walk away its not holding the time ,because its waiting for you to confirm time selected.So after you set the time press the clock key pad 1 more time .Remember this, just because you bought a new clock doesnt mean its a good part.Bad parts get the best of us ,so dont think your new part is ok yet.It probably is not.
I have a Rangemaster Classic 90 dual fuel that has problems igniting the gas hob.
Remove the flame spreaders and rings from the 3 rings you use the most, including the faulty one. Put them in a large pan cold water, add a teaspoon of dish liquid and slowly bring to a simmer. As soon as it want to boil over, blow on it and turn the heat off. Leave it to cool. Scrub with a plastic pot brush making particular attention to the holes. You had a blocked one which is the one that directs the gas to the spark igniter. Rinse and dry them, and replace to the hobs.
