20 Most Recent Rangemaster 110 (Gas) Kitchen Range Questions & Answers
Have had trouble with our timer on our Rangemaster 110 so ordered a new timer only to be credited as it is no longer available. Dont realy want to buy a new cooker this side of christmas, any way of bypasing the timer ?
Rangemaster 110... | Answered on Jan 06, 2019
Hello John,
these doors open on the side, they have the hinges under and above, with screws, at least when they look like the ones in the link.
These hinges can be adjusted with the screws at the bottom.
I wish you good luck, Dik
Rangemaster 5779 Tecnik Range Cooker 110 Dual Fuel NG Stainless Steel Oven...
Rangemaster 110... | Answered on Feb 27, 2018
Hi Tim,
I suppose it is the cooker of the photo, a Rangemaster Classic.
These doors open on the side.
There are 4 screws who fix them.
Unscrew them and you can take the door apartThe link is for the user manual. On page 18, fig 6.3 and 6.4, you find more information.
http://www.rangemaster.co.uk/media/868812/toledo-lidded-110-dual-fuel.pdf
Have a nice weekend, Dik
Rangemaster 110... | Answered on Feb 17, 2018
it is always terrible when items does not work as it should.
I expect that this cooker has flame safety.
The first thing I suspect, is your FFD (=flam failure device). Besides the burner are 2 points, one is for the spark, the other is the sensor for the safety device. On that point is connected a thin copper "wire" that goes to the tap. There it is screwed in.
The test is, stays the burner on when you keep the button pressed in. If that is the case, and the burner goes out after letting go the button, then I am sure it is the FFD.
I hope this helps, Kin regards, Dik
Rangemaster 110... | Answered on Feb 07, 2018
Lack of air to burn will cause this . air mix on burner needs adjusting . crack or leak on burner would upset flame . burner could need cleaning .
Rangemaster 110... | Answered on Aug 07, 2017
Ream out all the orifices and air venturi holes on the burner, adjust the air-ahutter, the air-shutter is usually nearer the valve/knob than to the burner. Yellow flame is an imbalance of fuel to oxygen and is creating Carbon Monoxide and not burning cleanly... this is the same problem that can make a furnace deadly. Blue flame=neutral flame.
Rangemaster 110... | Answered on Apr 27, 2016
Brian Moore... hello,
Beautiful unit...
It appears that parts are abundant... sellers on eBay
- I always make a rule of going to AT LEAST three (3) parts providers... with SEARS PARTS DIRECT typically being the highest cost...(but they have an excellent technical reference library).
If you can get the ACTUAL PART number off of your original documentation... you will be able to COMMAND the very best prices
Happy hunting...
Rangemaster Range Cooker Rangemaster Classic 110 Dual Fuel The Gas Company
Please do comment me back if I can be of assistance.
Water Filters Lawn Garden Appliance Parts
Rangemaster Spares Parts Accessories
Rangemaster 110... | Answered on Mar 29, 2016
That looks like a problem with the control panel assembly.
Try first unplugging power cord for ten minutes, then plug back.
Press the selector wheel for 5 seconds and see if this reset it.
If that does not work , then you need to replace the control assembly. YYou find diagrams and replacement parts by entering the model number here.
Rangemaster 110... | Answered on Mar 25, 2016
Most ranges can be converted to LP and it will be detailed in the installation manual. Good luck!
Rangemaster 110... | Answered on Jan 31, 2016
Try turning the power off and leaving it off to the oven for 15 minutes or so. Turn the power back on and see if you can reset the clock.
Rangemaster 110... | Answered on Oct 03, 2015
Try removing the burners and soaking in hot soapy water. If this doesnt work, an old trick is to burn the dirt out. Put the burner in the oven and bake it. The heat will soften any dirt and then washing the burner in hot soapy water usually removes the build up. Try poking a needle into the holes to clear them.
Two possibilities, either the bulb has failed, or the temperature sensor in the top has failed. Neither is likely to be an easy or cheap replacement.
Rangemaster 110... | Answered on May 18, 2015
call a service repairman I don't recomend anyone try to selffix GAS
Rangemaster 110... | Answered on May 17, 2015
If you are holding the knob in for a good few seconds and finding that it still goes out, the thermocouple has failed on that hob. The thermocouple is the metal spike sticking up when you take the ceramic plate and carrier off each ring. First check that the ring pieces are correctly sitting on the cooker, but if they are you will need that thermocouple replacing.
Rangemaster 110... | Answered on Feb 26, 2015
clean all of the holes the flames come ut f with a small brush t culd be clogged also lift range hod and look under it by the lines see that nothing is loose or obstructing the gas line
Rangemaster 110... | Answered on Dec 19, 2014
Rangemaster 110 (Gas) Kitchen Range Logo
246 questions posted
Top Rangemaster Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Thomas F. Schneider
Are you a Rangemaster Kitchen Range Expert? Answer questions, earn points and help others
View Most Popular
  • Rangemaster Kitchen Ranges
Most Popular Question
flame main hob range master 110 yellow
  • Kitchen Ranges
