20 Most Recent Jenn-Air ® 48" Professional Over The Range Hood, JXT9048CDP Questions & Answers
cream of tartar moistened with water and a paper towel
Jenn-Air ®... | Answered on Sep 30, 2013
wash rough dirt off first. Then use a rag and lots of soap to get rid of the grease. Then slightly soak a rag with vinegar. That should put a sparkle on things for you. Also, I use windex but instead of a rag or paper towels, I use newspaper. Just crumple up a piece and use it like a rag. This shines lots of stuff up and works best for cleaning windows inside and out.
Jenn-Air ®... | Answered on Oct 16, 2010
backsplash will not cause a problem unless this was the only open air space of the oven, if both left and right and back of oven are closed, this may cause a shortage of air to the oven. half inch to right and left of oven should be enogh. let it breath.
Jenn-Air ®... | Answered on Sep 03, 2009
Hi lillady909,
I'm Harvey the Master Plumber.
Your problem is: you cant get the lights or fan to turn on anymore is there a reset switch
First check the circuit breaker. If OK then check the transformer in the unit. It's next to the fan motor. If no power on the high side then you have a loose or broken connection. If you have no power on the low side the you have a bad transformer.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Jenn-Air ®... | Answered on Sep 27, 2008
Yes, it is possible.
You have to get the right orifice's for Natural gas. LP gas orifice has twice the size hole as compared to Natural Gas. Using it without the right orifice will put out way too much gas, and you will burn everything, as well as it will be a fire hazard.
Your local gas company or propane company should be able to get you the right orifice
Please rate this solution.
Jenn-Air ®... | Answered on Jul 31, 2008
if self clean works then sensor igniter did not need changing
sounds like the control was changed to c
top temp is around 550 f or 260 c
check your manual on changing range c to f
Jenn-Air Kitchen... | Answered on Mar 24, 2019
WE CAN NOT AS WE ARE NOT GAS SUPPLIERS HERE AND DO NOT RECOMMEND ANY DIY-ING FOR THEM GAS BLOWS UP WHEN DONE WRONG YOU SEE
Jenn-Air Kitchen... | Answered on Feb 23, 2019
slow lighting is not all that uncommon on these ranges. Make sure the burners are clean and that you can see the spark at each ignitor. If that is OK, check the gas pressure to the burners.
Jenn-Air Kitchen... | Answered on Jan 20, 2019
Fixya does not sell Jenn-Air control panels.
Jenn-Air Kitchen... | Answered on Jun 14, 2018
Jenn-Air ® 48" Professional Over The Range Hood, JXT9048CDP Logo
8 questions posted
Top Jenn-Air Kitchen Ranges Experts
Thomas F. Schneider
Craig Butler
Craig Butler
Paul Carew
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
View Most Popular
  • Jenn-Air Kitchen Ranges
Most Popular Question
recommend cleaning stainless range
  • Kitchen Ranges
