20 Most Recent
Rangemaster LEISURE 55 & 110 FAN OVEN ELEMENT-CLASSIC Questions & Answers
I have a Rangemaster Classic 90 dual fuel that has problems igniting the gas hob.
Remove the flame spreaders and rings from the 3 rings you use the most, including the faulty one. Put them in a large pan cold water, add a teaspoon of dish liquid and slowly bring to a simmer. As soon as it want to boil over, blow on it and turn the heat off. Leave it to cool. Scrub with a plastic pot brush making particular attention to the holes. You had a blocked one which is the one that directs the gas to the spark igniter. Rinse and dry them, and replace to the hobs.
Rangemaster LPG conversion?
If the LPG cylinders have the correct pressure regulator, no need to use an extra one but any regulator must be set to the correct pressure or removed.
