20 Most Recent Rangemaster Kitchen Hood Questions & Answers
In case you are still looking for an answer. The same happened to me.
I found a 3-amp fuse which I changed, and now it's ok.
I removed the chimney casing and located the electrical connection into the wall. You'll find a fuse unit within the switch which swings out.
Hope this helps.
Rangemaster... | Answered on Feb 07, 2019
Were you able to find a place to buy extra knobs for this range hood ? can you let me know ? sam@rossrealtors.com November 20, 2017
Rangemaster... | Answered on Nov 20, 2017
Extremely likely the fan motor.  get to it then , after removing fan blade,plug it in directly to a 110v  outlet ,just for a second to see if it works well( don;t touch it while prefoming this test,only the plug), or jumper out the switch(with electric disconnected) momentairly to see if the fan runs after turning the electric back on.
Rangemaster... | Answered on Jun 29, 2012
Get the full instructions in pdf from the Rangermaster site
Hope this helps.Thanks!
Please rate this answer.
Rangemaster... | Answered on Oct 23, 2011
Range hood motors, bathroom exhaust fan motors all share the same thing. They become coated with grime inside the shaft of the rmotor due to their exhaust feature of sucking dust and grime over the motor, which is open. The only solution is to get access to the motor and clean the fan blades and squirt a little WD-40 down the shaft as that is where the noise comes from. The dirt and grime build up on the motor shaft, and eventually starts rubbing the bushing where the shaft rest and makes a noise. Yo must remove this from the shaft and allow a little play, and lubrication which the WD-40 will supply.
Rangemaster... | Answered on Mar 26, 2011
The same happened to me. I found a 3-amp fuse which I changed, and now it's ok.
Hope this helps.
Rangemaster... | Answered on Dec 20, 2010
Rangemaster Kitchen Hood Logo
68 questions posted
Top Rangemaster Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Thomas F. Schneider
Are you a Rangemaster Kitchen Range Expert? Answer questions, earn points and help others
View Most Popular
  • Rangemaster Kitchen Ranges
Most Popular Question
4 year old rm5200 hood over stove
  • Kitchen Ranges
