20 Most Recent Rangemaster Classic 110 (Dual Fuel) Dual Fuel (Electric and Gas) Kitchen Range Questions & Answers
Hello Jeff,
it seems to me a problem with the timerfunction of the clock.
Clocks are the most source of problems, so when I refurbish a cooker and the timer does not work properly, I shortcut the timer as new clocks are very expensive.
In that case, the clock itself stays working.
For doing this, you need to lift the hob.
BE CAREFULLY, AND BE SURE THERE IS NO TENSION ON THE COOKER
I hope this will help you and I wish you a good weekend and a nice meal with your friends. Dik
Rangemaster... | Answered on Feb 17, 2018
This is usually a bad gas regulator.
Rangemaster... | Answered on Mar 08, 2016
Hi Helen.
Especially if you have a rig that calls itself Dual Fuel, it would seem that you should be able to convert. I looked up a manual for the Classic 110
http://www.rangemaster.co.uk/media/868812/toledo-lidded-110-dual-fuel.pdf Page 23 of the PDF (19 of the manual pages) specifically talks about there being conversion kits to swtich to different fuels. It also underscores that this should only be done by a certified gas engineer.
That said, my experience from shopping appliances for our house remodel several years back was that some sales people just stared blankly when we asked about running stoves on propane (we're a bit out in the sticks, no Natural gas hookups). Others would look at the same equipment and say 'oh, you need the converter fixture, which was more or less a flow restrictor to keep the energy content about the same as for the NG (propane is a bit higher energy content than NG).
In short, you should be able to convert between fuels, and the manual from the company itself says so.
Good Luck!
D
Rangemaster... | Answered on Jan 29, 2016
with the power off i would check the control switch, as it sounds like it has malfunctioned or shorted out. disconnect it and check with an ohm meter. or.....you need a qualified repairman. good luck
Rangemaster... | Answered on Jan 11, 2015
I just cleaned the inside glass on my maytag "gemini" and you take the inside door panel off, thencarefully lift out the glass and clean it.then reassemble. I found it easier to remove the door and lay it on thekitchen table with a blanket under it. Hope yours is similar as I suspect it is. Good luck and keep smiling. Please rate me...Thanks
Rangemaster... | Answered on Nov 25, 2014
if their is enough of a gap in the drawer , that allows you to see the object blocking it, then try using a spatula to push down on the item and move it back as I suspect that it is stuck on a small protrusion at the top of the drawer.
Rangemaster... | Answered on Nov 22, 2014
Check your breaker panel or fuse box to see if something is tripped. If you have a breaker panel, try flipping the stove breaker off all the way even if it looks like it is still on and then turn it back on and check stove. If you still have no power then you probably better call an electrician.
Rangemaster... | Answered on Aug 13, 2014
The glass lids usually sit in a frame with a sealant under them, you can remove and reset it carefully by using two small screwdrivers to go around the outside using the screwdrivers to (gently) like tyre levers lift it out. Take your time doing this be gentle and it will come out then put it back in square.
good luck Ray
Rangemaster... | Answered on Aug 11, 2014
It\'s possible you have a slow leak through one of the rail cocks ( gas taps) lift off the top and spray lightly some soapy water on the end of each of the rail cocks if it bubbles you have found the leak.
Rangemaster... | Answered on May 08, 2014
Rangemaster Classic 110 (Dual Fuel) Dual Fuel (Electric and Gas) Kitchen Range Logo
99 questions posted
Top Rangemaster Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Thomas F. Schneider
Are you a Rangemaster Kitchen Range Expert? Answer questions, earn points and help others
View Most Popular
  • Rangemaster Kitchen Ranges
Most Popular Question
need convert rangemaster from ng lpg but
  • Kitchen Ranges
