Freezers Logo
dan kuhn Posted on Jan 01, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Kenmore chest freezer does not stay below 30 degrees compressor runs but I don't see a fan to cool the compressor
Anonymous
Level 3:
  • Master 1,543 Answers
  • Posted on Jan 02, 2010
Anonymous
Master
Level 3:
Answers
1543
Questions
Helped
751654
Points
5690
If your chest freezer is less than 50 years old, it does not have a fan. Cooling coils contact inner walls of freezer compartment, warm coils dissipate heat through outside walls of freezer. If compressor runs, temp is 30+ degrees, gasket is OK, lid not left open, then you have one of two contions: 1. Low capacity compressor 2. Refrigerant leak. Solution to either is to replace freezer. (My opinion: Don't get a Kenmore brand, which generally ties you into poor warranty and slow and poor service.) No matter what brand name is on the freezer, it is most likely manufactured by Electrolux (in St. Cloud, MN) or Haier (from China). Look at the model / serial number plate before purchase to see where it was manufactured. Yes, the USA manufactured ones are better. (and I'm not just saying that because the plant is less than 15 miles from where I am sitting right now)
Arctic King (Midea) WHS-258CW1 chest freezer suddenly does not go below 55 degrees. Suggestions?
CALL A LOCAL REPAIR SERVICE IT MIGHT NEED FREON OR A NEW COMPRESSOR
Jul 21, 2021 • Freezers
My kenmore chest freezer is the garage, the temperature outside is over 30 celsius, the side of the freezer where the motor is is very hot, and some other places on the front and other side is warm to the...
The hot sides is normal, this is how they expel the heat from inside the freezer, sometimes it may help to use a fan to help cool. Also make sure there is about 12" of room around all sides of the freezer .
5helpful
2answers
I have a kenmore chest freezer model 19502/19702. I had it unpluged for 5 months. When I plugede it back in the power light flickers. Tryed other outlet. Other then that it seems to be working
We purchased this same Kenmore chest freezer model 19502/19702 in 2010. In less than 2 years the compressor quit. If you do a search on this model you will see dozens of complaints. Don't waste your time or money on this freezer.
Freezer has quit freezing only a little over a year old. manufactor date 6/2009 compressor is running will only cool down to 50 degrees thermostat set on coldest.
Is the compressor continually running? If so then there could be a leak in the system or the compressor is damaged. If it's running then stopping, the cold control (thermostat) could be damaged.
5helpful
2answers
Can a chest freezer be used in an unheated garage where the temeprature falls below freezing for an extended period? The garage is insulated so it doesn't get as cold as outdoors but it does drop below...
why not then when its down to zero shut the unit off and open the lid and free freezing...no electricity required....remember pop machines sit out in all types of weather
2helpful
2answers
Used chest freezer not cooling
chest freezer operation is among the simplest available. if the compressor is running and its not cooling there are only 2 possibilities. low or no refrigerant and or a bad compressor. so if you have the ability to return the unit I would. could luck peyton
1helpful
Kenmore 23.1 cf Chest Freezer not cooling below 14F
Make sure everything is working, I.E. compressor, fans. Now I need to know if the freezer shuts off at 14 degrees, or does it continue to run without making temp. If it shuts off, then the first place to look is the thermostat. It may be out of calibration. If it continues to run, then the solution may be as simple as cleaning the condenser coil. or the defrost has malfunctioned somehow. Defrost probleams will cause excess ice on the inside coil. You may need to remove the panels to see how much ice is on it. It sounds like the compressor is good, as it is pretty cold. Just not cold enough. A deep freeze should be at least 0.
2answers
Kenmore 14.8 cft - temperature between 5 and -22 degrees (-15 and -30 C)
Big...this is likely normal. I'm not sure where you're measuring that temp from. If it is the fan outlet, this is possible. The fact that the unit is staying below 5 degrees means that it is within spec. You do have a warranty. Ask Sears to come on in and check it out.
Your 'duty cycle'...that amount of time that the compressor is on should be about 20% of a unit of time...say 25 minutes out of 2 hours. Is that about right? If so, enjoy your ice cream.
Kenmore chest freezer.
Most likely a bad compressor. You could try a new relay on it first.
Top Freezers Experts
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you a Freezer Expert? Answer questions, earn points and help others
