20 Most Recent
Kenmore 15 cu. ft. Chest Freezer 16542 Questions & Answers
Freezer has quit freezing only a little over a
Is the compressor continually running? If so then there could be a leak in the system or the compressor is damaged. If it's running then stopping, the cold control (thermostat) could be damaged.
The compressor tries to start but cuts out with a
Please check current draw while compressor run, compare with its standard. If current draw it very high, your compressor is stuck up and need for replacement. Check also its capacitor for malfunction
Orange light in front is flickering almost
It is normal for those lights ot flicker.. as long as the unit is working then do not worry about that...the light really is just showing you that you have power to the unit...
heatman101
Where do i find the temperature control?
If your unit has a cold control it would most likely be on the side of the chest freezer near the front bottom. If you can find your complete model number from the tag on the freezer I could find out for you for sure.
Thanks
Temperature
If this unit has a control it would be located on the outer left side in the lower right hand corner. There would be a dial, the higher the number the cooler the temperature. Many of these chest freezers did not have an adjustable control.
Error code b on kenmore chest freezer
LOW / NO BATTERY ALARM
The Low/No battery alarm will activate when the
power level of the battery becomes low. The display
will alternate between "b" (Battery, See figure 8) and
the cabinet temperature, the red alarm light will
become illuminated and the control panel will beep
every five seconds. To stop the audible alarm (beep),
press the "ALARM RESET" button. The red alarm
light will remain on and the display will continue to
flash until a new battery is installed. This same alarm
will activate if there is no battery installed
