20 Most Recent Kenmore 14.8 cu. ft. / 419 liter Chest Freezer 11531 Questions & Answers
What is proper setting for upright freezer. my kenmore had setting at 0 degrees from factory. is that correct?
That should be ok. However -10 is more common.
1/30/2013 6:16:05 PM • Kenmore 14.8 cu.... • Answered on Jan 30, 2013
Kenmore chest freezer makes loud banging noise once in awhile what the problem
What is the model number of your unit?
11/22/2012 12:27:48 PM • Kenmore 14.8 cu.... • Answered on Nov 22, 2012
Kenmore 2539280412 upright wont stay cold
Check the thermostat of your Kenmore Dryer.For More information please visit Dryer Parts.
11/14/2012 7:37:01 AM • Kenmore 14.8 cu.... • Answered on Nov 14, 2012
0answers
0answers
Not a problem, just a
The basic principle on which a "Freezer" works would dictate that the answer to your question is "Yes", it would still "Freeze". It's what it's designed to do, as opposed to a refrigerator, which works on a different principle. http://home.howstuffworks.com/freezer2.htm
7/2/2011 6:24:10 AM • Kenmore 14.8 cu.... • Answered on Jul 02, 2011
0answers
I have a kenmore upright
I keep min two notches from the coldest setting.A great way to check where you should set yous,is ice cream.Put an open container of ice cream in the freezer,and turn the freezer to coldest.The next day try to scoop the ice cream.If the ice cream is hard the freezer is too cold.Adjust the freezer two notches ,and try the ice cream the next day.Repeat till you are happy with the hardness of the ice cream.It should be easy to scoop but not too soft.
5/17/2011 2:09:56 PM • Kenmore 14.8 cu.... • Answered on May 17, 2011
0answers
Meat is frozen but ice cream is soft
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
8/12/2010 3:41:23 AM • Kenmore 14.8 cu.... • Answered on Aug 12, 2010
Is it safe to plug a typical Kenmore
Safety is not an issue, the problem you may have, depending on the surge protector, is that when the compressor starts up the amps drawn from the circuit is very high which could cause the surge protector to trip, then the power would be shut off to the refrigerator,NOT A GOOD THING!
Good luck !
1/28/2010 8:17:27 PM • Kenmore 14.8 cu.... • Answered on Jan 28, 2010
2answers
Sears Kenmore Deep Freezer settings
i tilt my chest kenmore deep freezer to remove water when cleaning it by the time it was connected it didnt work
1/21/2010 5:53:58 PM • Kenmore 14.8 cu.... • Answered on Jan 21, 2010
Can I plug my freezer into a surge protector
i know where your going and its a good thought
read your compressor, it will label the start up amp,
it may even be on the model label
it will give you the rated amps and the start up amps
this is current draw to run
as well as start up a stopped motor
depending on the age
most units use about
short of that use a 3x method
if it has the run amp x3 is startup
then read your surge protector if its rated higher than the amps needed to start the unit
then you should be fine
i will say most SP are rated at 15amps
my freezer is rated at 18amperes
10/17/2009 6:54:43 PM • Kenmore 14.8 cu.... • Answered on Oct 17, 2009
My freezer sounds like its on, but it wont freez.
if the compressor is warm that is an indication to me that it is running or at least trying to run. if its running you should feel it vibrating as well as being warm. assuming the compressor is running and it's not cooling I would say you probably have a refrigerant leak and would come out cheaper to replace the unit. repalceing the compressor also is fairly expensive in exess of 300-400 dollars. Let me know if you have any other questions Peyton
3/8/2009 2:23:22 AM • Kenmore 14.8 cu.... • Answered on Mar 08, 2009
2answers
Used chest freezer not cooling
chest freezer operation is among the simplest available. if the compressor is running and its not cooling there are only 2 possibilities. low or no refrigerant and or a bad compressor. so if you have the ability to return the unit I would. could luck peyton
2/1/2009 12:30:43 PM • Kenmore 14.8 cu.... • Answered on Feb 01, 2009
Kenmore 14.8 cu. ft. / 419 liter Chest Freezer 11531 Logo
Popular Tags
35 questions posted
Top Kenmore Freezers Experts
Jay Finke
Jay Finke
ZJ Limited
ZJ Limited
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
View Most Popular
Kenmore Freezers
  • Kenmore Freezers
Most Popular Question
sears kenmore deep freezer settings
  • Freezers
