Miele W2240 Front Load Washer Logo
Posted on Jan 01, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Timer Jumps When set on a cotton wash which is supposed to take 1hr 26 the clock jumps after a few minutes down to 45 minutes. This doesn't appear to happen every time but I am monitoring. I think it might also happen on some of other wash programmes too.
Anonymous
Level 2:
Sniper:
  • Expert 70 Answers
  • Posted on Mar 29, 2010
Anonymous
Expert
Level 2:
Sniper:
Answers
70
Questions
0
Helped
107866
Points
206
Hi. The time displayed at the start of the program is an estimated time to complete the cycle. The appliance will calculate the wash time base on load size, water pressure, water temp ect. If a smaller load is to be washed then less water will be required thus shortening the time required to fill and heat water as a result this will reduce the wash time. EG. The more water you put in your kettle the longer it takes to boil.
Timer jumps
Who makes it and what's the model, please?
Does not go into wash mode but jumps to rinse and drain
Perhaps you already know how to do this; but if not, check out this video and learn to run a diagnostic test for error codes:
http://www.youtube.com/watch?v=yoCTzbl4FPs
Let me know.
I've recently purchased a FirgidAir laundry dryer (Model FCED3000ES ELE). The company installed drying time is 45 min that doesn't dry load well. I want to extend drying time to 1hr. Could you...
If you are looking to increase the time, the dryer comes with additional wheels for the timer. The one with the least number of posts is the longest time. I forget if it has two or three posts. You just remove the timer from inside the coin box and slip off the 45 minute wheel, and slide on the 1 hour wheel, and then put the timer back. Very simplet.
When I'm drying my clothes, I press the start button, and the timer says 26 minutes, but when the timer reaches 20 minutes, the timer jumps to 5 minutes, and then it jumps to 1 minute, and then it stops. I...
There could be moisture in the main board and this can cause this fuzzy condition. Usea good heater to dry the board , check for crusting on connectors, reconnect and test.
Jumps time on timed cycles- for example: High dry is 40 minutes time goes down to 36 minutes and then is jumps down to 23 minutes. Once it goes down some it might jump back up during the 20's then it goes...
Replace the timer, this is very easy. Un plug, remove access panel in the back and un plug the timer. This will be connected right behind the knob. It will be screwed down in front as well. Call your local dealership and get replacement part.
Washer is not washing the clothes properly. Skipping cylcles
If it's new - check if it's under warranty. Let them solve it. Save you money. You've already paid for it once.
Top Miele Washing Machines Experts
Paul Carew
vince
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
