20 Most Recent
Whirlpool WFW9200S Front Load Washer Questions & Answers
Instructions for thor th 85 washing machine
Hi I just bought a second hand THOR TWM800 washing MACHINE, do you knowwhich setting i should have the dial on to have a simple wash and dry clothes? Machine washes but doesn't dry.
12/21/2021 10:10:39 PM •
Whirlpool...
Answered
on Dec 21, 2021
I have Whirlpool model WFW9200SQA
The F24 error code as you have gathered on here refers to the temperature sensor is out of range and must be checked.To access the temp. sensor ya need to remove the lower panel below the door and check the temp. sensor by removing the wire plug to it and measure the sensor to be between
8.8K &9.2K (8.800-9,200 omhs) at room temp.
Good luck,i hope this help ya to fix your washer,
GENE
4/5/2017 9:11:32 PM •
Whirlpool...
Answered
on Apr 05, 2017
Our washer has a loud vibration while spinning.
It could be either bearing failure or the support arms that hold the wash drum are failing. If it is relatively quiet when in the normal wash cycle but noisy only during the spin cycle, means that the bearings have failed. It's an expensive job to replace since you need to tear the entire machine apart to get to the outer tub. Another reason is that the manufacturer does not sell you replacement bearings but you must buy the outer rear tub. Get a few estimates before deciding whether to repair or replace.
3/22/2015 7:28:32 PM •
Whirlpool...
Answered
on Mar 22, 2015
Lights on after replacing controller w10319816
1) you coulde be have both situationa) most of the time controller board coming faulty, you must returne the c.board and ask by another one is obligation of the company gave you another and return the old bad.b) you must shure that some instruction coming with the control board, you followed very WELL, for NOT damaged the electronic circuit., did you installed the wiring diagram o.k?God bless you
8/2/2012 11:58:20 AM •
Whirlpool...
Answered
on Aug 02, 2012
Error code F26
This error code indicates that the door needs to be opened and closed.
The F26 code may appear the first time you try to use the washer. Open and close the door to clear the display.
The F26 code may also appear if the washer has run three cycles without the door being opened. Open and close the door to clear the display.
If opening and closing the door does not remove the error display, press Pause/Cancel twice
10/24/2011 11:33:51 PM •
Whirlpool...
Answered
on Oct 24, 2011
I have a Whirlpool WFW9200SQA12 displaying error
Hi
F24
is a water temperature sensor error. You have to unplug the washer and check
the water temperature sensor and its connections, if that is fine then check
the resistance of the heating element and the part that is bad should be
replaced. Hope this helps...please post back for further
assistance.
Daniel
9/30/2011 9:05:56 PM •
Whirlpool...
Answered
on Sep 30, 2011
Will not finish the wash cycle and it flashes F21
If this is a Whirlpool manufactured FRONT LOADER (such as Kenmore, Fridgidaire and later model Maytags), "F21" is a Long Drain error code. This is an indication that you may have an obstruction somewhere in the drainage system. Most commonly, this is an indication something is lodged in the drain pump or the inlet line running from the wash tub to the pump. There is a white screw off cap on the drain pump that you can remove to inspect the pump impeller and clean. The following link explains:
http://www.fixya.com/support/r3608588-f21_error_code
Included is a follow-on link that explains how to check the drain pump to clean. On some model washers there is no screw off cap on the pump and you will have to remove the inlet hose that runs from the bottom of the wash tub to the inlet side of the drain pump. Removing the inlet hose for inpsection is recommended on all these washers just to ensure there isn't anything lodged in the line. Debris and small articles of clothing such as socks or under garments can become lodged in this area as well causing the drain cycle to fail.
NOTE: The washer will not complete a wash cycle until the conditions causing the error are corrected. In addition, a "SUD" or "SD" (Suds lock) error code can also often occur in conjunction with the "F21" error code. This is due to air being detected in the drainage system, which can occur if the pump is not running, or if you have an obstruction BEFORE the pump. You need to remove the inlet hose from the pump to ensure it is also not blocked. Correct your drainage system fault, and the SUD error (if displayed) should go away.
NOTE: If these preliminary measures do not correct your problem, you may have to replace the drain pump. It does not take much to damage the pump impeller or motor. Since the error code is generated if the drain cycle exceeds 8 minutes, if the pump is damaged and can't pump at the required volume, the error code will continue to appear until the pump is replaced. If the pump requires replacement, the following link explains how:
http://www.fixya.com/support/r3574350-replacing_the_drain_pump_in_a_front_load
These are very simple repairs that you can perform yourself without the assistance of a repairman.
If the wash tub is full of water, you may want to use a wet/dry shop vac to pull a vacuum on the drain line and drain the wash tub. This will minimize any potential mess you may have to clean up.
Replacement parts (if required) can be purchased at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between sites, so shop and compare. The first three sites listed also have helpful exploded view parts illustrations to assist you with locating and properly identifying the parts you may need.
NOTE: The error codes are not listed in the owner's manual. For an explanation of all the error codes, each one of these washers comes with a technical data sheet inside.
To access, you will need to remove the lower toe panel under the door. The access screws are located under the bottom front edge of the panel. You may have to prop the two front feet of the washer up for better access ( a 2x4 works well for this). With the screws removed, the panel should drop down, then come off. If the tech sheet isn't directly behind the panel, it will be affixed to one of the interior cabinet walls.
The tech sheet lists all error code definitions, troubleshooting data, diagnostics procedures and wiring diagrams. I mention the tech sheet because you may need it to troubleshoot this error code.
Read through the information provided and if you have questions, please post back with your MODEL NUMBER and let me know. I hope you find this information helpful. NOTE: If you determine the pump to be defective, and the pump housing is still in good condition, you only need to replace the pump motor. However, the pump is usually sold as an entire assembly and the motor CANNOT be orderd as a separate item. There are several outlet stores that advertise on ebay and sell the pump motor for much less than ordering an entire pump assembly. Replacement is simple and you do not have to remove the pump from the washer. Just drain the pump as previously mentioned and disconnect the electrical plug from the motor. Remove the three screws holding the motor to the pump housing and replace as necessary. Just make sure the o-ring is intact and in place. To get a good seal, you can lubricate the o-ring with a thin film of petroleum jelly.
5/3/2011 6:09:25 PM •
Whirlpool...
Answered
on May 03, 2011
What does the code F35
The F35
indicates that the main control board detects a problem with the analog
pressure sensor (water level pressure switch) in the washer. This
component senses and controls water level in the washer. This failure
could
be caused by a pinched or broken air hose between the air trap at the
bottom of the washer tub and the analog pressure sensor. It can also be
caused by a clogged air trap or a failed analog pressure sensor. If you
are able to unplug the washer and pull off the top panel, you can
check for the probable cause of this failure.
To remove the top
panel,
remove the screws on the very back of the panel that secure it to the
washer
cabinet. Pull the top panel back slightly and then and off of the
washer. It is on the side wall just behind the expansion control board.
You
can check the air pressure hose connection and the wire harness
connection on this component.
This component costs around
$99.This information was based on the general description of the washer
model that you provided (Kenmore Elite front load washer). There are
several different models of this washer.
3/24/2011 1:01:16 AM •
Whirlpool...
Answered
on Mar 24, 2011
The rubber ring inside the washing machine came
that rubber is called the bellow. snap the bellow back to the machine. place plastic ring over it into the grove and work it all the way around. that metal ring should have a spring on it. use a needle nose pliers and pull the spring so it stretches, metal ring should snap right in place.
2/5/2011 7:56:40 PM •
Whirlpool...
Answered
on Feb 05, 2011
How to clean filter
Unbolt the
front bottom cover (3 screws) and you will see big knob where all the
bad stuff is trapped.
11/21/2010 3:49:15 AM •
Whirlpool...
Answered
on Nov 21, 2010
Have a whirlpool duet apparently to much clothes
It appears your vibration damper has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
9/30/2010 7:41:39 AM •
Whirlpool...
Answered
on Sep 30, 2010
