It sounds like your memory card has got
some problems. For the inner saved images, you'd better apply a photo recovery
freeware to restore all your wanted photos back:
http://www.freeware-fix.blogspot.com/2013/02/photo-recovery.html
Don't worry! This freeware was found as the
camera of my friend was mistakenly formatted. All his contained photos were
gone after the formatting process. But, this freeware finally restored all his
photos back.
So, you also can take a chance with it
here:
http://www.freeware-fix.blogspot.com/2013/04/data-recovery.html
PS: If you don't want to face the similar problems, you'd better back
up them all well.
The reason this occurred is that you likely never formatted the card. The card will work fine in the beginning but eventually will corrupt.
Take no more pics until you've recovered the photos, take the card out of the camera. Here's some freeware photo recovery software that should be what you're looking for.
You will need to use a flash card reader with this software. If you don't have one, get one, they're inexpensive.
Finally, AFTER you've recovered the photos, format the card in your camera to prevent this from happening again. Keep in mind formatting will also totally erase your card, so again only do this after you've recovered the photos.
