What Jerr isn't telling you is the link is worthless. RemingtonPower is no longer in business. Sorry
Lou
Please follow this link, http://www.fixya.com/support/t2629831-ad... cursor down to “Best Solution”, while there click the “Was this helpful? [Yes]” button. Simple, functional, & inexpensive. HTH
Lou
There was a change to your pole lock using a lever pn 121560-01, but like 99 of 100 RemingtonPower parts it is NLA
pn 121560-01 is the lever. Type it into the "Part #:" window and the answer is NLA at
Remington.com
http://www.desaparts.com/index.htm
Do an Internet search for Remington 121560-01
M & D Mower say they have one $37.50
http://www.m-and-d.com/order.html?id=R3X...
I wouldn't waste any time. Good Luck
Lou
I use M & D for McCulloch parts. They have been good to me. Call them, it isn't pictured but for that money I'd wager it's a replacement for the nut assembly you have. Sooner or later you will need a part that cannot be found. Even when this thread is closed you can still reply to me below the advertisements. If you opt for the new part please let me know how it worked for you. TIA
Lou
Direct link
http://www.m-and-d.com/CEN-121560-01.htm...
Part #807 E-Z lock from Pentair will solve the problem. Have to remove rivets and replace with bolts. Trim plug to get nut on pole.. nut has same threads as cracked one. Reassemble, good to go. $9.00 from Amazon.
