20 Most Recent Remington 16" Electric Chain Saw Questions & Answers
Oil leak on Remington electric chain saw model
check oil lines and when storing saw stand on end or on side blade up.. vote if'n i was of help.. remember BUY USA MADE PRODUCTS.. Jay
4/10/2019 2:44:47 PM • Remington 16"... • Answered on Apr 10, 2019
Motor of the saw runs,but
your clutch is bad and how old is this saw if it is too old it would not be worth fixing
8/28/2017 10:42:35 AM • Remington 16"... • Answered on Aug 28, 2017
I need the manual for 107624-02
should be a 5/32 file
2/12/2015 2:09:40 PM • Remington 16"... • Answered on Feb 12, 2015
2answers
16" Electric Chain Saw: what kind of oil is used for electric chain saw...
I assume you are asking about the oil for the chain. Any good quality "Bar and Chain Oil" will do fine. Do not use motor oil you use in your car engine as it will not properly lube the chain and will result in quicker dulling and early demise of the chain.
You can get the "Bar and Chain Oil" at most hardware stores or Farm Supply stores.
12/31/2014 5:41:14 AM • Remington 16"... • Answered on Dec 31, 2014
0answers
2answers
The switch of the saw is not working 00
You need an AC voltmeter to trace the problem with the switch. It can also be a bad motor brush/spring--these saws are great for killing motor brushes, and there are virtually no replacements available as Remington has ceased saw operations. If it is a bad brush, visit an electrical tool shop to see if they have something that will work from a different brand of tool. Good luck!
4/16/2014 10:21:59 AM • Remington 16"... • Answered on Apr 16, 2014
SAW WILL NOT START
Not that I know off. But it could be. look at the owner's manual to find out. Since it is electric, it may have one . It could also be the switch . So look at that possibility too. Try different cords and different outlets to make sure it is not one of these.
11/23/2013 11:22:19 PM • Remington 16"... • Answered on Nov 23, 2013
Chain came off remington chainsaw now will not run
If you can't move the chain around the bar it is too tight.Back off the tension.Put on some gloves and see if it will move. If it was so loose that it came off the driver links could have been damaged and you will need to replace the chain because the drivers have burs on the side of them and are to wide to slide in the grove of the bar
11/4/2013 11:22:23 PM • Remington 16"... • Answered on Nov 04, 2013
0answers
Oil type m16
Be the first to answer 10/19/2013 3:30:23 AM • Remington 16"... • Posted on Oct 19, 2013Be the first to answer
0answers
LOST SET SCREW FOR TIGHTEN OF FASTNER ARM
probably Metric.. go to a hardware store with the saw and get one that fits
10/5/2013 7:51:46 PM • Remington 16"... • Answered on Oct 05, 2013
Missing oil cap
http://www.masterparts.net/remingtonelectricchainsaw.html
4/5/2013 9:02:03 PM • Remington 16"... • Answered on Apr 05, 2013
0answers
Manual
Be the first to answer 8/1/2012 4:08:45 AM • Remington 16"... • Posted on Aug 01, 2012Be the first to answer
Remington 16" Electric Chain Saw Logo
131 questions posted
Top Remington Garden Experts
Jay Finke
Jay Finke
Thomas Perkins
Thomas Perkins
ADMIN Andrew
ADMIN Andrew
Are you a Remington Garden Expert? Answer questions, earn points and help others
View Most Popular
Remington Garden
  • Remington Garden
Most Popular Question
need order new 16 chain remington chain
  • Garden
