Hello, Your problem is either going to be the pressure switch or the inlet valve. To figure out which when the cycle starts and the water is pouring in pull the power cord. if the water stops it means you have a bad pressure switch. If the water does not stop it means your problem is with the inlet valve being stuck open. Hope this helps! Mike
