20 Most Recent Kenmore 23822 Top Load Washer Questions & Answers
This is an easy one to solve. Those are moving pins , when in transport. When it is delivered, the delivery people simply just pull on some straps and the pins fall in the cup. You need to keep these when moving washer to put back in, so not to damage anything.
Kenmore 23822... | Answered on May 09, 2019
Hi, I think the trip going is an electrical fault, DO NOT BYPASS IT, but, with power OFF AND UNPLUGED, meter both power wires to earth, (chassies) you should not get any readings. If it happens at the same point in cycle, that might narrow down the fault, i.e, every time the machiene pump emptys, its the pump/wire to it. Any doubt, get it sorted by a reliable tech guy, and good luck finding one of those!!
Kenmore 23822... | Answered on Dec 17, 2017
It sounds like the clutch has gone in the base of the machine. You need a service engineer.
The lid switch is there to make it impossible to have the lid open when the machine is spinning. Opening the lid when the machine is spinning puts the breaks on the clutch. There was a case of a child last year who poked an object into the catch so he could watch the machine spin. He put his arm in for some reason and his arm was ripped off.
Kenmore 23822... | Answered on Dec 10, 2017
first check the lid switch-mike
Kenmore 23822... | Answered on Apr 14, 2014
You'll really will need the spanner wrench for the spanner nut on the basket drive block. If you try to make a tool or use some other method, you risk injury and possibly damaging your washer basket.
The spanner wrench is made by Supco, part #TB123A. It has various other part numbers from the appliance manufacturers. It is compatible with Whirlpool, Maytag, GE, and Kenmore. Most Kenmores are made by Whirlpool.
If you want the wrench same day, call local appliance shops and ask if they sell the spanner for the Kenmore Series 90. I got mine from a local shop and paid $13.
You could also buy one on eBay or another reasonable online source.
http://www.ebay.com/sch/i.html?_trksid=p2050601.m570.l1313&_nkw=tb123a&_sacat=0&_from=R40
Or Google search: TB123A
Don't pay more than $20 including shipping.
You can always sell it on eBay once you are done with it. It won't lose much value being used since it doesn't really wear out.
You'll need a hammer too, preferably with a hard rubber head, or use a wooden mallet. If you use a steel hammer, be careful when you strike the spanner wrench to loosen the spanner nut. Wrap the steel hammer head in an old washcloth or rag. You don't want to accidentally strike the porcelain enamel lining of the basket - it will chip and that can lead to rust of the metal.
Kenmore 23822... | Answered on Apr 13, 2014
Timer is defective. Your unit has a netural drain. When finished agitating, the shuts down and then starts up reversing to drain and spin. On the initial reverse start, the water drains without the transmission spinning. After a timed period 3-4 minutes, the timer is supposed to pause, stopping the motor for a few seconds. When the motor stops again, the transmission shift to the spin cycle and when the timer resumes power tothe motor it should spin. You are doing the same thing when you lift the lid...stopping the timer and then the tranny shifts and when you set the lid down, the washer spins. Replace the timer.......
Kenmore 23822... | Answered on Feb 27, 2014
Fix the timer on the washer so that it fills with the correct amount of water, and so there is the correct amount of time for each cycle. Make sure the washer is unplugged and take off the control knobs and the panel that lays over the knobs. The knobs could be either at the front or back of the machine. Check the wires that link the timer to other areas of the washer. If they are slack, push them further into place with pliers.
Change the timer by disconnecting the old one. Make sure the new timer is made for the brand of washer that you own. Unhook the wires to the old timer one at a time and connect each wire to the new timer.
Kenmore 23822... | Answered on Oct 26, 2013
It is probably your lid switch. Use a pen to push in the switch, if you do not hear a click when depress, replace switch
Kenmore 23822... | Answered on Oct 19, 2013
Kenmore 23822 Top Load Washer Logo
466 questions posted
fordexpert
Harvey Mahal
Kristen Denison
Kristen Denison
Level 1 Expert
View Most Popular
  • Kenmore Washing Machines
Most Popular Question
when washer spin light lid lock keeps
  • Washing Machines
