20 Most Recent Crosley CAWC529JQ Top Load Washer Questions & Answers
uplug power. remove switch, then tape the wires together. this will make a complete curcuit, so it should run. good-day !
Crosley... | Answered on Jun 03, 2017
check back of unit as the concrete on the back may of been dislodged check not over loaded also the belt maybe loose or streached
Crosley... | Answered on Mar 08, 2015
The machine thinks the door isn't closed. Could be due to a faulty door switch or control board.
Crosley... | Answered on Jan 03, 2015
Likely possibilities:
  1. Coupling between motor and transmission has broken.
  2. Transmission has failed.
Number 1 is cheap and relatively simple to replace. Tip the machine up in front and place a support under the front edge of the cabinet. Look for broken pieces on the floor. See if you can freely rotate the motor shaft without affecting the transmission shaft. Check that the transmission shaft can be turned by hand. If yes to both, replace the coupling. If it breaks again after a short time, transmission is likely bad
Number 2 is expensive and difficult. If the coupling's not broken and the motor is operational, OR the coupling breaks again after only a short time, then replace the transmission, or the whole machine entirely.
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect. If the water flows though the inlet then the flow pressure should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash. Test a pressure switch: Click on : http://www.youtube.com/watch?v=HZZ2bDMspj8 Check this link to replace the inlet valve: http://www.espares.co.uk/advice/washing-machines/a/7/1408/how-to-replace-the-inlet-valve-on-a-washer-dr.html
Crosley... | Answered on Sep 04, 2014
check the knob it is probably broken
Crosley... | Answered on Jun 10, 2014
there is a clutch coupler that has probably gone bad
there are 2 screws holding it in place you can undue them and pull it out from between the tub and top of washer then splice the switch in. MAKE SURE YOU UNPLUG IT FIRST
Go to sears web site and you can see the break down on parts
dont interrupt it. if it is an older machine it may not have the capability to pick up where it left off
Crosley... | Answered on Apr 07, 2014
Crosley CAWC529JQ Top Load Washer Logo
100 questions posted
Top Crosley Washing Machines Experts
Steve Allison
Steve Allison
jdthefixer
Evan Benson
Evan Benson
Are you a Crosley Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Crosley Washing Machines
Most Popular Question
bypass lid switch
  • Washing Machines
