20 Most Recent Amana 3.2 cu. ft. Top-Load Washer Questions & Answers
2answers
Drum leans to one side when washing and spinning
You most likely have a weak spring or worn spring mount. If the tub is not hitting the sides of the washer then you will be fine running it like that.
1/14/2022 7:09:03 PM • Amana 3.2 cu.... • Answered on Jan 14, 2022
2answers
How do you remove the agitator on amana washer
Unplug the Amana washing machine from the wall outlet, and open the lid. Pull the liquid fabric softener dispenser straight off of the top of the agitator. Some Maytag washers require the use of a flat head screwdriver inserted between the dispenser and the top of the agitator. Twist the handle of the screwdriver to pop the dispenser off of the agitator.
Remove the barrier cap inside the agitator using your hands. Pull the barrier cap straight out of the agitator. There is an O-ring that attaches to the outside of the barrier cap. If it did not come out with the cap, pull the O-ring out of the center of the agitator.
Remove the bolt securing the agitator to the drive bell with the socket wrench. The bolt is inside the center of the agitator.
Place your fingers in between the bottom of the agitator and the tub. Lift straight up to remove the agitator from the tub. Keep your head out of the way in case the agitator is stuck and unexpectedly releases. If necessary, use agitator hooks. Insert them under the agitator and push down on the hooks to release the agitator.
7/3/2018 6:06:57 PM • Amana 3.2 cu.... • Answered on Jul 03, 2018
2answers
Fault code on an Amana Washer
The door is open. Be sure that the door is completely closed.
6/6/2018 12:34:32 AM • Amana 3.2 cu.... • Answered on Jun 06, 2018
Transmission refill capacity
Contact support staff at www.searsdirect.com they may be able to help.
7/11/2017 6:53:28 PM • Amana 3.2 cu.... • Answered on Jul 11, 2017
0answers
Gunk gets on clothes-stains them,i pulled agitator out and cleaned it off ran bleach thru-its better but still getting on clothes
The problem may be the seal on the transmission failing. If this happens, grease from the transmission (necessary for it to function) will leak and float (recall from science class that oil is less dense that water) up into the washer. As the grease enters the tub, it stains your clothes. Washer Transmission Replacement Whirlpool Kenmore Top Load Washing Machine... Washer Leaks Water GE Top Load Washer Tub Seal Replacement Part WH02X10383
1/21/2016 8:41:07 PM • Amana 3.2 cu.... • Answered on Jan 21, 2016
0answers
Water will not fill
The other item to check would be your water inlet valve. Check it for continuity with a multi meter it should show Ohms or a closed circuit. To test it when water is overflowing unplug the unit and see if it still overflows or continues to fill. If it stops when unplugged. Then it is not a water inlet problem but an electrical signal problem going to ur water inlet valve. Possibly from the panel or board.
4/11/2015 9:44:13 PM • Amana 3.2 cu.... • Answered on Apr 11, 2015
Amana washer wont agitate
No agitation? first use a multi meter and check ur water pressure switch? that is what sends the machine the message to start wash cycle? You can test it with a meter and with a manual test? ( first locate it in the panel, it has a plastic clear tube hose going into it, remove that tube from its connection, now put another small tube or hose into the slot where it was and have the machine set to wash cycle with water in it. Blow into the other end of the tube. If the machine starts to wash. the pressure switch is more than likely good ( No wash- then THE DIAPHRAGM IS BAD AND SWITCH HAS TO BE REPLACED) another test u can do is Remove the hose and submerge in water. Seal one end and blow air into the other end and look for bubbles. Check for an obstruction in the hose as well. Or take the original hose tube and plug one end and blow into it AT the other end, it should be hard and have pressure, if it is easy to blow and u dont feel any pressure and it feels like the air is going out ? Sometimes they get busted open or a pin hole and release air causing the water switch diaphragm to not open. Another test u can make with a multi meter is by testing the prongs individually. # 15,16,17 (don't worry to much bout the numbers IF U GET THEM WRONG) place ur meter prongs on both out side prongs or connectors of the switch. (where the wire plugs into) take note of weather it shows OHMS or infinity ( open or close circuit) ? Now place the meter on the left outside and the middle prong, take note agin what it shows. Now place meter prong on the right outside and the middle prong. Agin take note what reading u get. ( you should actually get a reading of infinity in 1 and a reading of continuity or ohms in the other 2? Now the tricky part. Agin place a small tube or hose into the switch and blow into it, using the meter do the same test agin on all prongs. But now keep the pressure on the switch when u blow into it, in other words use ur tongue on one end of tube to not allow air to escape. When u test it agin now one of the prongs that once read infinity should now show continuity or ohms, and 1 of the other prongs that read ohms should now read infinity or open. . If both check ok then next CHECK the motor coupler (a bad couplercan be checked by looking under the machine and taking note if there is a black residue on floor, look at coupler located between the motor and tranny, and see if it is broken up or missing any parts? Try to turn shaft by hand and notice if it does not engage tub? ) or belt if belt driven. Check for loose, broken or worn belt . Then check the door switch with a multi meter for continuity OHMS when door closed and infinity when door is opened , and if there is a little movement on wash cycle in 1 direction only then check the cam dogs in agitator. ALSO CHECK THE CAM DOGS INSIDE THE AGITATOR, AS THEY WILL HINDER THE AGITATION PROCESS.
4/11/2015 9:35:05 PM • Amana 3.2 cu.... • Answered on Apr 11, 2015
How to fix amana w10240534c washer wont fill?
check your water inlet valve. Check it for continuity with a multi meter it should show Ohms or a closed circuit. To test it when water is overflowing unplug the unit and see if it still overflows or continues to fill. no fill If it stops when unplugged. Then it is not a water inlet problem but an electrical signal problem going to ur water inlet valve. Possibly from the panel or board.
4/11/2015 9:19:53 PM • Amana 3.2 cu.... • Answered on Apr 11, 2015
What happened in transit to make my amana washer not run? When I press the on button it makes a noise like a solenoid operating, and then nothing
DID U REMOVE THE MOVING STRAPS BOLTS FROM THE BACK THEY WILL BE ALONG THE BACKWALL COVERED WITH A BIG PLASTIC PC SHOULD BE VERY NOTICABLE, THEY MUST BE REMOVED B4 USING MACHINE
4/11/2015 8:57:12 PM • Amana 3.2 cu.... • Answered on Apr 11, 2015
Won't spin water out of clothes
check pump or for blockage
3/1/2015 12:34:20 AM • Amana 3.2 cu.... • Answered on Mar 01, 2015
My Amana washer makes load noises during wash cycle, what could cause that?
transmission bearings are the problem and transmission needs to be replace in order to fix the problem, in some cases some people chenge only the bearings but is better to replace the transmission at once.
12/3/2014 2:05:42 PM • Amana 3.2 cu.... • Answered on Dec 03, 2014
Why would my Amana washer not do anything but fill up with water. Nothing will function at all on all the cycles but the fill. It doesn't even click on the timer when you try to set to any setting exc
Hi Kirby First... Caution Because your dealing with water & electricity it can be lethal to fiddle around inside. That said... Washing machines are controlled by a master timer unit, usually mechanical, but rotated by an AC Clock motor. If the timer is not getting voltages to the various Switches around the "timer unit" or "clock motor" then the individual selected functions won't work. Manually Rotating to a particular function then Activating the On/Off Push/Pull switch should start things happening even if timer motor is dead. So If your OK with AC electrical goods then open it up. Connection wires may have fallen off or something simple. A multimeter is your best friend here. Look for the big rotary clock behind the main control dial. Listen for the clock motor running. The main Push in & out Button is the On / Off switch. Check that its got AC on the input wire & switches across to the other wire when the knob is pushed in / out. This may be the problem... You can always call an appliance repair technician! Good Luck
11/21/2014 3:22:03 AM • Amana 3.2 cu.... • Answered on Nov 21, 2014
Amana top load washer running water in. Is lid suppose to lock while doing this?
it sounds like the logic board has an issue. and is resetting to start then cycles off and back to start.
9/25/2014 6:31:02 AM • Amana 3.2 cu.... • Answered on Sep 25, 2014
Amana 3.2 cu. ft. Top-Load Washer Logo
263 questions posted
Top Amana Washing Machines Experts
Virgil Watts
ZJ Limited
ZJ Limited
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Amana Washing Machines
Most Popular Question
belt off put
  • Washing Machines
