That model has 2 hinges on the door, and one or both of the hinges are probably bent, not the door. The good news is that they are pretty cheap to buy the hinges, and it only involves 8 screws, its an easy fix. After you do that, if you still have problems with the door lock, then it probably got damaged from the door closing when it was bent, and you would need to replace either the door lock or the door strike if the strike on the door is broke. I have replaced many of these hinges for this problem, and havnt come across the door lock getting damaged in the process, but have had to replace a few broken door strikes. hope this helps, good luck.
