20 Most Recent
Frigidaire FTF2140FS Front Load Washer / Dryer Questions & Answers
I washed a bath mat and it became undone in the
if it is a top loader , remove the agitator and get the n bits out of the tub
there is not normally a filter to the pump so bits may ne in the impeller of the pump stopping it from turning
Where is the coin catcher on a frigidaire front load washer?
Good Afternoon Friend,
I understand you want to know where the coin catcher is located. The coin catcher is located inside your washer, at the bottom right-hand side, attached to the drain pump. If you want to get to the coin catcher, I suggest contacting your local authorized technician for assistance. Hope this is helpful.
-Best Regards-
WP
Frigidaire front load washer LTF2140FS2 stops after every cycle and the start light blinks
Good Afternoon Nicole, thank you for allowing me to assist you!
Typically, the Start light flashing indicates that the cycle has paused or the door is not securely latched. If the hose is not clogged and the door is closing properly, then more than likely your washer is experiencing a communication problem with the control board or wiring issue. At this point, I would strongly recommend contacting a professional to make the necessary repairs.
Best of luck!
Owners manual for model#FTF2140FS
my washer will do all the cycles but will not spin out the water I have tried to run it through an other cycle sometimes it works sometimes it don't any suggestions
The delay start light on
First I made sure the detergent dispenser door was closed. That did not work. Then i made sure that the dispenser was clean, by running water thru it. That did not work,. Then I turned the dial to hand wash and pushed the start button. That worked. Delay light did not turn on. Then i turned the setting to the proper wash cycle and pushed the start button. Clothes are being washed now.
The 8-hour delay will not reset
You can try this is you want. I can't promice you yhat it will work but it might be worth a try.
Make sure the washer is on
Press and hold the "SPIN SPEED" and the "SOIL LEVEL" buttons together, continue holding the buttons until a signal sounds then release them. This should reset your washer to the default factory settings.Hope it works for you. And you might also try unplugging it and see if it will reset it. GOOD LUCK !!
Do not spin
Hello - Is the washer making a humming noise? If so, either the drain hose or pump is clogged and needs to be cleaned. Is the door securely latching? If it is not, then the door latch assembly may be faulty. Try reprogramming the unit by flipping the household circuit breaker off or unplugging it. Wait approximately ten minutes and restart washer. If it proves to be ineffective, contact a certified technician to accurately pinpoint any potentially more serious issues like a faulty pump, time or control board.
Flaching lights on control panel
Hello Robert Costain - Do you notice any error codes on the display or any audible beeps? Try resetting the unit by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and restart unit. Select a normal cycle and verify if it will start. If it proves to be ineffective, the unit may possibly have a faulty door lock assembly, wiring failure or a communication problem with the control board. I recommended contacting a professional to move forward accurately and to properly assist with the repairs.
What make my wash machine want spin out?
Hello diane_burgma - Does the unit make a humming noise? If so, either the drainage hose/pump is clogged and needs to be cleaned. If not, the washer may possibly be experiencing an issue with the door lock assembly, faulty pump, timer or control board not communicating correctly. Contact a professional to move forward accurately to properly diagnose and repair the unit.
