Question about Canon PowerShot SD780 IS / IXUS 100 IS Digital Camera
Left canon sd780 out in the rain. with new battery lens attempts to open but get "lens error, restart camera"..... is all hope lost??
6ya staff
SOURCE:
Anonymous
SOURCE: lens error
Have same problem as above. Apparently the gears in the lense slip a tooth, they can be re-aligned but this involves taking out the barrel, my question is, how do you do this as I don't want to pay Canon the AU$250 for a new barrel.
Posted on Oct 15, 2009
t00nz
CameraR
  • 4738 Answers
SOURCE: my canon powershot a590 camera lens is stuck. When
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But here are some things that you can do to try to correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, or if repair costs close to the value of the camera, they're worth a try.
Posted on Feb 07, 2010
chelseawells
chelseawells
  • 11 Answers
SOURCE: Canon powershot SD780 is camera. Camera shows the
There's really no way to restart it if there's a physical problem with the lens. Try to power it on again but if that doesn't reset it, the camera needs to be serviced. A great site for help with these is: camerasandparts.com They just specialize in service for the Canon Powershots and nothing else, they are fantastic if you need help with one of these problems. Try them, your exact SD780 lens error restart camera problem is right on the site for the SD780. Good luck, that's the place for help with a powershot, it just sucks that it happened while you are on vacation.
Posted on Jun 23, 2010
lock123
Andrea Lock
  • 6831 Answers
SOURCE: canon powershot sd780 is error message ' lens
Hello
The problem is that the lens has become stuck in the barrel after dropping it. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful.
Regards
Andrea
Posted on Aug 23, 2010
Kiran Anto
  • 420 Answers
SOURCE: Canon Ixus 900 Ti ~ Lens error Restart camera
Problem: dust in the gaps near lens which makes it jammed. Effect: the sceen shows blk color. Solution: just blow over it or vaccum it.
Posted on Sep 11, 2010
Lens frozen message lens error restart camera cannot get it to do anything
I have a possible answer to your problem but FIXYA will not let me send it to you.
Oct 10, 2011 | Canon PowerShot SD780 IS / IXUS 100 IS...
My Canon SD780IS beeps three times and then Lens Error, Restart Camera comes up. What can I do Camera is less than a year old.
This is a common problem if the camera has been dropped. Canon can take care of the problem if the camera is under warrenty
Nov 20, 2010 | Canon PowerShot SD780 IS / IXUS 100 IS...
Canon powershot SD780 is camera. Camera shows the canon screen then turns black and beeps three times then says "lens error restart camera". I don't know how to restart...i need to use it I'm on a trip...
Jun 22, 2010 | Canon PowerShot SD780 IS / IXUS 100 IS...
Canon IXUS 100IS - 'Lens error, restart camera' message
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try:
Mar 20, 2010 | Canon PowerShot SD780 IS / IXUS 100 IS...
My camera says lens error, restart camera - and wont take the lens in.. what du i do? how du i restart?
This is probably THE most common failure among digital cameras.
There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Feb 21, 2010 | Canon PowerShot SD780 IS / IXUS 100 IS...
Lens error restart camera
try these:-
  • connect it to pc and on it
  • vaccum the barrel of lens
  • changing mem. card and batt. for 2min.
  • shake it.
  • on and off in different positions
  • hit the part near lens softly with palm (trust me this made mine work)
Aug 11, 2009 | Canon PowerShot SD780 IS / IXUS 100 IS...
Canon PowerShot SD780 IS camera lens error. :(...
I did the same thing and it works only be restarting it now but it works lol. I threw it agianst my bed . SO BEAT THE **** OUT OF YOUR CAMERA..then restart and it should work..*** made **** what can you say
Jul 28, 2009 | Canon PowerShot SD780 IS / IXUS 100 IS...
Canon PowerShot SD780 IS / IXUS 100 IS Digital Camera Logo
Top Canon Cameras Experts
old marine
old marine
Doberman
Ekse
Are you a Canon Camera Expert? Answer questions, earn points and help others
