Garden Logo
Posted on Sep 27, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Trying to get my weed eater to start
I am trying to get my feather lite weed eater to start and im am just needing some advice on what things to look at
Anonymous
Level 3:
  • Master 398 Answers
  • Posted on Sep 27, 2009
Anonymous
Master
Level 3:
Answers
398
Questions
Helped
170315
Points
1257
I have been told not to but I use starting fluid to start mine. just one ir two short sprays.
On a featherlite weedeater what's the small green thing that's stuck in the gas cap vent on the inside of cap called???
It is either the tether or the non-return that lets air in, but doesn't let gas out. Most parts are obsolete.
Trimmer parts list - Weedeater Featherlite
http://www.weedeaterfeatherlite.com > parts
Weedeater Parts · 1. Handle · 2. Isolator-Handle · 3. Nut · 4. Screw · 5. Shroud · 6. Shield-Heat · 7. Screw · 8. Screw
Weed Eater Featherlite Type 1 Gas Trimmer Parts
https://www.ereplacementparts.com > weed-eater-feathe...
Need to fix your Featherlite Type 1 Gas Trimmer? Use our part lists, interactive diagrams, accessories and expert repair advice to make your repairs easy.
Featherlite (Type 1) Weed Eater Trimmer - PartSelect
https://www.partselect.com > MFGModelNumber
Get Parts and Repair Help for FEATHERLITE Weed Eater Trimmer - Gas Trimmer. View parts like Engine Fuel Filter and Fuel Line.
2answers
Where is the air adjustment screw located on a Feather Lite Fl 20C Weed Eater?
The adjustment screw on the feather lite can be flush in the carburetor but i do believe you'll need a special type screw driver to adjust that carburetor. I've seen some screws with splines on them and some with a slot. The air adjustment on that model is very finicky so take your time.
How to change the fuel filter on a Weed Eater Feather Lite FX265Xtreme 25cc. The weed eater stars but won't run.
Use a hooked piece of wire to snag the filter through the fuel tank, it should pull off the fuel line.
3helpful
Feather lite trimmer only runs on half throttle and idle dies on full throttle. unit is new
When I bought a new poulan gas trimmer, I had the same problem. Solution was to return it and get another one. They come with problems, even new. Just keep returning them until you get one that works correctly. Mine works great, but like I said, had to return it and get one that was right.
Need to know the gas ratio to use in a homelite(trimlitr) weed eater.
50:1 if that is too rich the weed eater will give off white smoke then use 30:1
1helpful
25cc Weed Eater
Yes. any 2 cycle oil will do. It is right do not use marine oil it runs alot thicker than 2 cycle oil.
Jul 06, 2010 • Garden
1helpful
I have a feather lite weed eater xt26 and it will
Sounds like you will need to clean your carburetor.
Sometimes you can get by with priming it a few times, and letting it
run a few times like that and it will flush the gunk out of the jets,
but most of the time you will need to rebuild the carburetor.
If the mower is over a couple years old, then I also recommend that you
buy and install a new carburetor repair kit, because the diaphragm will
get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, count the
number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns
they were in/out.
Please rate me, Thanks
Good Luck, I hope this helped
May 08, 2010 • Garden
Poulan chain saw after carb rebuild.
Is thereadjustment somewhere on the saw
I think there is 2 .
Top Garden Experts
Jay Finke
Jay Finke
john h
