20 Most Recent Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin Questions & Answers
I have Poulan 2375 wild thing thing chain saw I replaced plug coil carb fuel lines filters checked spark put gas in cylinder. No luck
As you have done most things regarding fuel system i would have to assume it either has not enough compression, or the ignition timing is out, so remove the muffler and check the condition of the piston face through the open port, any signs of scuffing or marking on the piston then the saw has seized at some time and the piston ring is stuck in, if all appears ok then remove the flywheel and check the key has not sheared, the key is alloy and is part of the flywheel..
4/21/2018 9:42:18 PM • Poulan Wild... • Answered on Apr 21, 2018
Bar oil in piston
HI you may have broken or worn piston oil rings or damage piston on the inside diameter
1/12/2018 12:38:04 AM • Poulan Wild... • Answered on Jan 12, 2018
Chainsaw fuel line diagram
12/12/2017 8:01:09 PM • Poulan Wild... • Answered on Dec 12, 2017
2answers
Wont stay running when you let off the gas???
Sound like the carb was never adjusted right. Unfortuatley, the carb adjustment screws require a certain tool that's not available to the public. (EPA thing) You'll have to take it to a shop to get it adjusted. That should solve the problem.
11/19/2016 10:59:18 PM • Poulan Wild... • Answered on Nov 19, 2016
Adjustment for coil. how many thousands of "
most coil to flywheel adjustment is fixed by the mounting screws it will be around .002" or have clearance as close to the flywheel without touching it as contact is a dead short
2/27/2016 9:42:20 PM • Poulan Wild... • Answered on Feb 27, 2016
Connected carburetor to prima bulb& tank
Here is the way to hook up the fuel lines connected-carburetor-prima-bulb-amp-0snlkc2idhfslary3a2ev3kp-4-0.jpg Note: I put it together outside of the saw so you could see how it is hooked up. Fuel filter/pickup >>to>> Inlet on carb >>to>> Outlet of carb >>to>> to inlet on Primer bulb(shorter post) >>to>> Outlet of primer(longer post) >>to>>Fuel tank (usually has a retainer in tank to prevent fuel line from coming out.)
2/10/2016 12:10:20 AM • Poulan Wild... • Answered on Feb 10, 2016
I wat is the ratio for 1 gallon of gas
I use 50:1 mix in every two stroke engine I own, Cynthia. Anything less could result in damage to the engine. However, if you buy Poulan oil for the saw, it may even have the recommended mixture in the fine print on the lable. I use Stihl oil in everything regardless of brand. I suggest not using bargain basement two stroke oil from bargain stores. Too heavy of a mixture, you will find excessive smoke and have more of a chance of fouling the spark plug. I have seen some small engines that wanted as heavy as 32:1 ratio, but you almost had to wear a respirator to run them.....
11/27/2015 3:07:47 PM • Poulan Wild... • Answered on Nov 27, 2015
Need spark plug gap
I've never heard of the saw but it is probably a McCullock derivative. Try either 0.5mm or 30 thou (of an inch). It won't be far out and should get you out of trouble.
10/2/2015 8:31:46 PM • Poulan Wild... • Answered on Oct 02, 2015
Warm weather cranking instructions?
After your saw sits for any extended period of time, it is suggested to drain all the old gas out of the tank and replace it with fresh mixed fuel. Currently we are being provided 'summer blend' fuel in warm weather and 'winter blend' fuel in the winter. All fuel now being 'oxygenated fuel' has a tendency to lose its oxygenation which changes the blend (for lack of a better description). Old winter fuel can make a saw diffficult to start in the summer and vice-versa. I wouldn't suggest running fuel with a high blend of alcohol because alcohol has a tendency to 'draw' moisture from the surrounding air and you can end up with water in your tank or gas can. Alcohol can also deteriorate rubber components and cause fuel delivery problems due to swollen or cracked lines. Never store your gas container directly on concrete or directly on dirt because that will cause moisture to condense on the inside surface of the fuel container above the level of the fuel. Always store gas cans on a rubber mat or on a wide board. Always keep the filter clean and sawdust out of the carb vestibule area to minimize contaminates entering the system. I'd suggest a full choke and a few sharp pulls until the plug fires, then go to half choke and pull sharply again and get ready to finger the throttle a bit until it warms up fully.
9/20/2015 11:52:00 AM • Poulan Wild... • Answered on Sep 20, 2015
2answers
McCulloch chain saw wont stay running after it
Is the chain brake engaged? The brake lever should be in the back position. Toward the handle.
was this helpful?
yes
no
8/23/2015 4:06:41 PM • Poulan Wild... • Answered on Aug 23, 2015
0answers
Poulan chain saw wild thing will not start
simple things first right fuel /oil ratio in tank ? aircleaner not blocked off with sawdust? stop switch set to correct "run" position , switch not broken damaged ? chain brake set ? choke set correct to start ? primer bulb working correctly , fuel is visible inside bulb
8/4/2015 2:32:20 AM • Poulan Wild... • Answered on Aug 04, 2015
Where is fuel tank breather on poulan 2375 wild thing chain saw?
in the fuel cap ?
8/4/2015 2:26:24 AM • Poulan Wild... • Answered on Aug 04, 2015
2answers
Saw starts but chain wont spin?
The clutch is not working.
7/28/2015 6:20:09 PM • Poulan Wild... • Answered on Jul 28, 2015
Fuel line rotten, fell off into gas tank. Is there
Yes, it is called Tygon, and you can get it from your laawn and garden store. If you need further help, I’m available over the phone at https://www.6ya.com/expert/matt_8dbc24bf722649ac
7/2/2015 9:45:44 PM • Poulan Wild... • Answered on Jul 02, 2015
Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin Logo
546 questions posted
Top Poulan Garden Experts
Jay Finke
Jay Finke
Thomas Perkins
Thomas Perkins
Sean Wright
Sean Wright
Are you a Poulan Garden Expert? Answer questions, earn points and help others
View Most Popular
Poulan Garden
  • Poulan Garden
Most Popular Question
poulan 2375 wild thing thing chain saw
  • Garden
