Checked all drains and they are clear
SOURCE: LTF2140E Front loader washer
My Frigidaire front loader washer model LTF2140E doesnt want to drain the water when set to wash (heavy-normal-quick selectors). It washes put thats it. I have to switch the selector to drain/spin then rinse/spin cycle to finish the load. I checked the drain hose for any clogs....everything is clear. Any suggestions? Also,iIs their any reset buttons for this type of washer?
SOURCE: Maytag Model # MAH4000AWW Neptune
Clean out your filter after ref. to user's manual. Try some WD40 on the door mechanism (on machine), lock & unlock door 5 or 6 times while machine is off.
SOURCE: Stops mid-cycle, does not drain, displays nd error code?
Hello.
That code is telling you that the unit is draining to slow. After 15 minutes it is not below the low water level and will not spin out. The best repair for this is to replaced the pump on your unit.
SOURCE: washer will not drain or run. It gives a code nd
Mine doing same thing, "ND" code coming up. I just replaced pump, 1/2 way thru wash same code came up. Blew out hose going into main house drain, also house drain. Still not working. Is there a trap somewhere or what am I missing? A reset maybe? Help thanks
