20 Most Recent
Maytag MAH6700AWW Neptune Front-Load Washer Questions & Answers
What does the F30 code
The F30 error code indicates an issue/error with the Dispenser System. It occurs when the dispenser motor cannot be driven to its proper position.
12/5/2022 2:49:38 AM •
Maytag...
Answered
on Dec 05, 2022
Model MAH4000, will not spin out, door lock will
Check if the "locked"or "door locked" light comes on. If it does not, you need to replace the wax motor in the door lock assembly and the machine control board, which is inside the control panel. The control board is expensive, so instead of buying the whole control board, if you're good in electronic repair and soldering, try checking ebay for the control board repair kit. Search for "MAYTAG NEPTUNE WASHER R11 Q6 REPAIR KIT". It has all instructions how to do the repair. Good luck!
10/9/2019 1:18:47 PM •
Maytag...
Answered
on Oct 09, 2019
Washer does not remove water in final spin
If washer hums when it should spin, and the washer will not drain, you may have 2 issues.
First check that the drain pump, drain hose, and wall drain are free of debris.
The washer may not spin properly if the drain system is not operable.
Once you are sure the washer drain pump, drain lines, wall drain, and drain hose is okay, run a test wash.
If the washer hums but now drains, you fixed one issue.
If the washer still hums, you may have a bad belt, motor coupler, motor itself, etc...
Check parts for wear and replace as necessary.I pulled the drain impeller and found a sock from my little guy stuck in there. Fixed!
check all water outlets to make sure there is nothing blocking the pipes.
you could also go to this link it might help you out.....
Washer does not remove water in final spin Google Search
10/24/2017 12:16:20 PM •
Maytag...
Answered
on Oct 24, 2017
How do I stop the error E2 code on my washer? I
The E2 shows that there is a motor problem. This can be caused by having an extra heavy load in the machine so take some out and try it. It can also be cause by any iof the buttons being stuck so make sure they are all 'free'. If this fails then you will need to have a new motor and call a repair man unless you can do the job yourself.
6/5/2016 10:16:35 PM •
Maytag...
Answered
on Jun 05, 2016
How to fix leak from soap dispensor
I assume you have water coming out of the dispenser and running down the front of the machine. You probably have a build up of soap powder in the water inlet and it is restricting the flow and backing up.
Soap powder is only partially soluble in cold water and a residue of undissolved powder builds up over time, one of the reasons I use a liquid detergent. Remove the dispenser tray, it should pull out fairly easily with just a little resistance. Try and clear any blockages, hot water is best as it dissolves better. Clean the tray you have removed and re-assemble.
12/7/2015 4:57:12 AM •
Maytag...
Answered
on Dec 07, 2015
Why slow spinning?
a slow spin sometimes indicates that a out of balance switch might be malfunctioning
11/1/2015 10:26:11 AM •
Maytag...
Answered
on Nov 01, 2015
