It may be failing to boot. In this case, press the reset button, then you can access the firmware upgrade page on http://192.168.1.1 on a wired ethernet port.
It will not be serving DHCP, so you will need to configure a static IP on your PC to access it.
You can download firmware from D-Link
Dsl2640b router power light shows red but should be green
RESET button for 10 seconds it is in back side of router. So all settings are defaults.
Then connect your router to computer with ethernet cable then access it with following link
http://192.168.1.1
or
http://192.168.0.1
type user name as "admin' and password as "admin" or blank or "password"
then configure again as your internet service provider settings then check.
I was banging my head for 2 days with about 35 different configurations and finally tried the following and it worked just fine. Also, tried connecting 3 computers and they all connected with "NO" issues. Even connected wireless with "NO" issues. Now I am at 20mb download speed...J compared to AT&T 1.5mb download speed.
This is my DLINK model -> (DIR-601 Wireless N 150 Home Router Wireless router)
1. Reset your Comcast Surfboard Cable Modem by unplugging it for 5 minutes.
2. Then reset your DLINK Router to the manufactures default settings. Then Unplug DLINK Router for 1 minute then plug it back in (Just plug your cat5 cable into port 1 and connect it to your computer) there should not be anything else plugged into the DLINK Router at the time you make the changes. Just 1 computer can be connected.
3. Went into the DLINK configuration 192.168.0.1 and changed the PPPOE setting that I was using for my AT&T Modem to Dynamic IP (DHCP). Once you make the changes save them and then unplug your DLINK Router it's off.
4. Turn on Comcast Surfboard Cable Modem and wait until all lights are on. Now plug in a cat5 cable from the Surfboard Comcast modem (NOT A CROSSOVER CABLE LIKE THE CD INDICATES) to the INTERNET port of your DLINK Router. Now turn on your DLINK router.
5. Then turn on your computers or restart them and it will pick up IP Addresses from your DLINK Router
