Review parts diagram for traction drive at following JD URL.
https://partscatalog.deere.com/jdrc/sidebyside/equipment/76075/referrer/navigation/pgId/124294503
comment here for further assistance.
SOURCE: husqvarna yth1842xp 2005 ride on mower won't move in gear
your linkage came apart from the way it sounds. most all these riding lawn mowers are simple machines. you need to fallow the(flopppy lever) and see where it go's it is supposed to attach to a rod or cable and must have came unhooked
SOURCE: Drive belt install on JD GT275
The bracket with loops keeps the belt in position when it is slack (disengaged). The bracket usually has to be loosened to even get the new belt on, the belt ONLY runs on the pulleys.
SOURCE: I have 2001 Husqvarna lawn tractor model YTH1746 wnt go into gear
those fluid drive transmissions fail on quite a few brands as they all use the same ones....replace the trans...they are expensive but still cheaper than a new mower.
SOURCE: drive belt routing for LX178
Go to this website, upper right hand corner and do a parts look up.
Search for your model and that good stuff they ask of you and then
choose mower housing should be there, browse the site it's really cool
and has a lot of info.
http://www.jackssmallengines.com
I did a
sample search for generic riding mower deck and found great diagram of
belt routing. Give it a try you will find same results Good Luck! Don't forget the thumbs!
