20 Most Recent Kirby Ultimate G Bagged Upright Vacuum Questions & Answers
My kirby ulitimate G series will not turn on
HELLO,
PLEASE SEE MY TROUBLESHOOTING GUIDE...
http://reviews.ebay.com/COMMON-PROBLEMS-WITH-THE-KIRBY-VACUUM-TROUBLESHOOTING_W0QQugidZ10000000003800312
MANY OTHERS HAVE HAD SUCCESS WITH DIAGNOSING AND FIXING THEIR OWN KIRBY USING MY GUIDE. I HOPE THAT YOU ARE ONE OF THEM... :0)
MARCI
11/1/2019 6:01:05 PM • Kirby Ultimate G... • Answered on Nov 01, 2019
4answers
Kirby shampooer dispensing - NOT a filter problem
I had the same problem and I called my local Kirby guy, he's great, helped me when I thought I blew my kirby up, it was just a cord and he wa able to tell me that over the phone. When I called him with this problem, he knew right away that it was only putting out a thin strip in the middle only. The first thing was I needed that little screen, the second was the hole where the screen goes has a white tube that goes from that hole to the bottom of the tank, its kinda in the corner and I never thought it would have anything to do with the problem. He said I needed to run hot water in it and clean it cuz I was going to have to blow in it, yes, with my mouth. I ran it under hot water for a few minutes and then with hot water in the hole, blew into it. I did this a few times, checking the tube ending each time. After a few times, water was shooting freely through the tube. Problem solved, I think, I'll be shampooing tonight so i'll know for sure then. An alternative to blowing with your mouth would be using a can of air, didnt think of it till now and I have 1!
9/8/2019 11:59:36 AM • Kirby Ultimate G... • Answered on Sep 08, 2019
3answers
Wattage for Kirby Sentria G10D
The conversion of Amps to Watts is governed by the equation
Watts = Amps x Volts
For example 1 amp @ 110 volts = 110 watts
your case 7 amp @ 120 volts = 840 watts
unless you are running it at 230v but I don't think you can
I would look for one rated for Volt-Amps instead of watts
It's best to round up to be safe add 40 - 60 watts
Don
4/17/2019 4:52:27 PM • Kirby Ultimate G... • Answered on Apr 17, 2019
Kirby uprigt bagged diamond edition lost it's suction
make sure it has a clean bag and not clogged up
2/20/2019 4:38:47 AM • Kirby Ultimate G... • Answered on Feb 20, 2019
The outer vacuum bag stink. We were told it could be washed. Is that true?
Yes. You can take the filter bag off the Kirby. just press the button at the top of the bag to release the bag, and just unscrew it at the base... and hand was in warm water using some nice smelly detergent.... hang out in the sun to dry..... and replace the paper filter bag more often.... I need to as I have 3 dogs and the dog hair does smell after a few days inside the filter bag, so I replace the filter bags quite often to stop any smelling... Bugbuyer
12/29/2018 11:51:41 PM • Kirby Ultimate G... • Answered on Dec 29, 2018
2answers
Sparks from the Kirby Motor
1. Do you think this may be the problem?
YES
2. How come it continues to rotate?
Motor armature consists of multiple coils and just some of them burned so even though it keeps spinning it does not function properly.
3. Do I need to replace the armature?
We have switch replacement instructions HERE and they will take you as far as accessing the motor. We do not have motor assembly instructions yet but if you get that far - motor is not that hard to reassemble. You may have to spend some time getting tolerance ring back in and make sure you install finger spring properly.
Good Luck
10/6/2018 4:13:17 PM • Kirby Ultimate G... • Answered on Oct 06, 2018
Kirby Tradition servicing
Servicing what part of the machine? Can we get more info?
12/27/2017 1:59:44 PM • Kirby Ultimate G... • Answered on Dec 27, 2017
How do I make my upright Sentria Kirby into a
Hello, this is Ava with Think Crucial. You may find the User's Manual for your Kirby model by clicking the link below. http://kirbywhq.powweb.com/manuals/Sentria/1DD280D45F1ECC76092C85D13B557CE2/Sentria-Manual-Rev-K.pdf You can purchase a wide variety of high quality Kirby replacement parts for your Kirby vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10 https://www.thinkcrucial.com/collections/vendors?q=Kirby I hope this was helpful. Ava B. Think Crucial Customer Care http://www.thinkcrucial.com/
12/8/2017 7:54:54 PM • Kirby Ultimate G... • Answered on Dec 08, 2017
The auto drive doesnt work. The lever even fell off the back.
Its not a simple fix, it will involve some disassembly of the motor unit, especially if the mechanism would not change from neutral to drive. One of the vac experts at vacuumland.org, a collector and enthusiast website, may be able to provide detailed instructions with pictures.
11/28/2017 6:55:14 PM • Kirby Ultimate G... • Answered on Nov 28, 2017
I need to find an instruction manual for the Kirby
Hello, this is Ava with Think Crucial. You may find the User's Manual for your Kirby model by clicking the link below. http://kirbywhq.powweb.com/manuals/UltimateG/77A0CF1A5F7DB07CF87DB5A31B84CF28/UlimateG.pdf You can purchase a wide variety of high quality Kirby replacement parts for your Kirby vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10 https://www.thinkcrucial.com/collections/vendors?q=Kirby I hope this was helpful. Ava B. Think Crucial Customer Care http://www.thinkcrucial.com/
11/26/2017 10:41:43 PM • Kirby Ultimate G... • Answered on Nov 26, 2017
Kirby diamond vacuum manual download
Hello, this is Ava with Think Crucial. You may find the User's Manual for your Kirby model by clicking the link below. Kirby Series Owner Manual You can purchase a wide variety of high quality Kirby replacement parts for your Kirby vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10 https://www.thinkcrucial.com/collections/vendors?q=Kirby I hope this was helpful. Ava B. Think Crucial Customer Care http://www.thinkcrucial.com/
11/21/2017 5:51:28 PM • Kirby Ultimate G... • Answered on Nov 21, 2017
Green light flickering!
only use a genuine kirby belt. not copys that are sold on the web. it sounds like one of the end bearings is jammed with human hairs, remove end cap and cut out with a stanly blade
8/24/2017 12:45:36 AM • Kirby Ultimate G... • Answered on Aug 24, 2017
Thank you for the detailed explanation regarding
Your best to go onto youtube for instructions on how to shampoo.
8/24/2017 12:25:47 AM • Kirby Ultimate G... • Answered on Aug 24, 2017
Kirby Sentria brush roll not rotating
HELLO,
MY GUESS IS THAT YOU ARE NOT SEATING THE BELT PROPERLY BEFORE PUTTING THE NOZZLE BACK ON THE MACHINE. PLEASE FOLLOW MY GUIDE STEP BY STEP AND IT SHOULD SOLVE YOUR PROBLEM...
http://reviews.ebay.com/CHANGING-THE-BELT-ON-A-KIRBY-G3-G4-G5-GSIX-ULTIMATE-G_W0QQugidZ10000000003720039
HOPE THIS HELPS...
MARCI
5/15/2017 1:16:18 AM • Kirby Ultimate G... • Answered on May 15, 2017
Ok, my kirby just stopped working. I had someone
When was your Kirby made? If you have an older Kirby, inside where the motor lies is a single or double magnet with a spring coil attached to it. Within that coil is a filament wire held together with a shiny disk at other end. This filament does go bad from time to time and needs to be replaced. This usually is not a do it yourself job. If you can find the proper filament, you might but usually there are several types and sizes, let your local distributor change it for you.
4/11/2017 6:16:05 AM • Kirby Ultimate G... • Answered on Apr 11, 2017
Voltage of light bulb in kirby ultimate g7
The bulb is 12 volt
2/18/2017 2:16:42 AM • Kirby Ultimate G... • Answered on Feb 18, 2017
3answers
Why am I getting a smell out of my Kirby when I am
If it is a burning rubber smell then that means that the belt needs to be changed. Here are the belts you need:
Kirby Ultimate G Belts
12/22/2016 10:43:15 AM • Kirby Ultimate G... • Answered on Dec 22, 2016
2answers
Kirby sparks and smells
it probably needs new carbon brushes in the motor,DO NOT run anymore for fear of burning motor out.
11/6/2016 2:21:32 PM • Kirby Ultimate G... • Answered on Nov 06, 2016
Kirby Ultimate G Bagged Upright Vacuum Logo
733 questions posted
Top Kirby Vacuums Experts
Mike Cairns
Mike Cairns
Paul Bade
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
View Most Popular
Kirby Vacuums
  • Kirby Vacuums
Most Popular Question
shampoo upholstery
  • Vacuums
