SOURCE: Error Paper output slot
SOURCE: Canon MP610 - Paper jam error message
PLEASE REMOVE THE POWER CABLE AND REINSERT IT IT SHOUL BE OK AND IF STILL PERSIST JUST RESTART THE PC IF STILL RESIST PLEASE LET SOME TECHNICIAN TO CHECK FOR THE SENSOR FOR THE PAPER JAM ...
GOOD LUCK
SOURCE: I have a Canon MP470 that pulls 1/2 sheet paper and then jams
Paper feed roller
cleaning
When paper does not feed
properly.
To clean the paper feed
Machine button
SOURCE: Error - Paper Output Slot
Same error, but could see anything in the slot at all from either end. Our solution, we manually turned the roller wheel inside the pronter and forced a piece of paper through. After pushing and pulling the paper back and forth a couple times, a hair band came out (presumably the handy work of our 18th month old daughter). Problem solved.
