Sears has a repair guide as well as online internet chat. I have no knowledge of this error, and only used Google to search for help.
https://www.searspartsdirect.com/washer-repair/error-codes/maytag-bravos-mvw-top-load-washer-error-codes.html
https://www.searspartsdirect.com/repair-guide/washer/how-to-replace-a-water-inlet-valve-on-a-top-load-washer.html
SOURCE: WHIRLPOOL RF385PXG
If a new temp sensor doesn't fix an F3, you have a loose connection, or the electronic control is bad.
SOURCE: fault code f1 maytag bravo
F1 indicated machine controller has failed and will need to be replaced.
SOURCE: Maytag Bravo Washer flashes F50 code
Most likely a bad machine control,can also possibly be a motor per whirlpool but I have never had to change a motor,changed a lot of machine controls.
SOURCE: Maytag MER5730ACW Stove.F3 fault code.
hello there
Please go thru this list of the fault codes for this appliance it will tell lyou what to do for the fault or what part needs to be replaced
MAYTAG FAULT CODES
Maytag Range / Stove / Oven Fault Codes
Failure Code
Fault Code Description
Solution
F0
Function key stuck
Replace touch pad or if touch pad is part of the clock, replace the clock
(ERC).
F1
Defective touch pad or clock (ERC)
Replace touch pad or clock (ERC). Touch pad is a more common problem.
Refer to F1 test at the top of this page for more information.
F2
Oven temperature too hot
Replace relay board, if present, or oven temperature sensor (RTD). Check
sensor harness.
F3
or
F4
Shorted or open oven temperature sensor (RTD)
Check sensor harness and harness connection between oven sensor and oven control.
Replace oven temperature sensor (RTD) if wiring is ok.
F5
Watchdog and hardware conflict
Replace clock (ERC).
F7
Function key shorted or stuck
(ERC).
F8
Analog / Digital problem
F9
Door latch
Check door latch components.
Find Parts
SOURCE: Whirlpool gas range model gw395leps00 error code e2 f3
The F3 E2 error code indicates that the electronic oven control board in the range senses an over-temperature condition in the oven.
This can be caused by a failed temperature sensor probe, a wiring problem between the sensor and the control board, or a failed electronic oven control board.
If the oven is apparently not overheating when this error code appears, then your likely failure is the temperature sensor probe.
If the oven is overheating, then you likely have a failed electronic oven control board due to a stuck relay not cycling the oven heating element off properly.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question####
