20 Most Recent
Maytag MAH6500 Neptune Front Loading Washer w/Built in Water Heater Questions & Answers
Maytag Neptune MAH8700AWW Error Code Hr
When starting the spining cycle I could observed that the pump's cable touch the metal floor. When that happen the "Hr" error code appear inmediately. Conclusion: With years of use the cable's insulation was wear out. I strap the cable so it can not touch the metal and problem solved. Hint: You should also check the dampers (4) for excesive wear.M.Caro
Maytag Neptune m/n MAH3000AWW burnt R11 resistor
STOP
There is a short in the door lock (very, very common problem )
Go to ebay and search neptune washers and im sure youll find a site i was selling a kit to repair this. If you cant find it let me know ill look .
Maytag front loading washing machine
This worked for me for the E3 error code: Turn the machine off and then on. Enter the Service Mode by pressing the Chime and Exrta Rinse keys for 3 sec. Display the Diagnostic Codes by pressing the Rinse and Spin key. Clear the codes by pressing the Delay and Chime keys for 3 sec. Turn the machine off, unplug and plug in the power cord. This dumps the memory. Evidently, if it gets full, it causes problems with the programming and messes up the cycles.
Maytag Epic-Z F-28 error code
F28 is a misc error,
most of the time it is because the washer is NOT LEVEL.
1. Unplug waher,
2. Relevel washer. (make sure all legs are equally distributing weight, so as to ensure no shaking). See owner's manual.
3. Plug in, and use.
Hope this helps.
Jay
I have the MAH8700AWW model and the smell is awful!
I have read that the imbalance/drum problem is a known problem and should be covered under warranty.
also, that the smell is also a known problem and can only be fixed by replacing the outer gasket. Which seems like a waste of time, as how long would it take for the new gasket to smell?
Door won't open on my front loading maytag washer
Try unplugging machine and then plugging back in see if that resets it. Also if you still cant get it unlocked there is a emergency latch release. Remove the 4 phillips head screws holding dispenser trim/lid. Now look in in front of (closest to door) now look for what appears to be a weed eater line (it should be green) pull gently and it should release door. Hope this helps get to your sons socks.
Error code od maytag Neptune
http://homeguides.sfgate.com/maytag-neptune-washer-model-mah8700-troubleshooting-codes-102595.html. Here's the site for Maytag Neptune Washers. You can also find other modes there. Hope this helps. Enjoy.
