SOURCE: Dell A960 cartridge problem
Does the black cartridge print? If not did you take the tape off of it? Error 50 is a generalized error reading relating to a number of cartridge problems. If the color cartridge is empty, it may be theproblem although I have not found this to be true on Dell printers. If you remove the color cartridge and reinstall it the reading will indicate its full (even though it isn't. This may solve the problem.
SOURCE: black ink is faded
Open the kodak all in one home center on your desktop and click on [?] on top most right hand side.
choose maintenance under general links and choose printhead cleaning. if this does not solve the issue,
call kodak @ 1800 421 6699 and they will replace the printhead for you free of cost.
SOURCE: I just installed new ink
ower
off the All-In-One and remove the power adapter (brick) from the back
of the unit. Wait 20 seconds, reinsert the adapter, and power the unit
on.
Did the error message return?
Yes: Continue to step 2.
No: Print a test page. If the test page prints, the error is resolved.
Reset the All-In-One's factory defaults (click here for instructions).
Yes: Continue to Checking the Cartridges.
NOTE: The embedded links lead to specific troubleshooting documents.
Step
Action
Open the top cover of the All-In-One. Remove both cartridges. Close the top cover.
Power off the All-In-One and remove the power supply brick from the back of the unit.
Reinsert the power supply brick into the back of the All-In-One and power the unit back on.
Does the error message reappear?
Yes: Skip to Contacting Lexmark below. There is a hardware issue with your printer and you need to contact our technical support center.
No: Continue to step 4.
Clean the cartridge contacts (click here for instructions) and the AIO carrier contacts
(click here for instructions). Continue to step 5.
5
Power the AIO on, reinsert the black/photo cartridge, and close the top cover. Power the All-In-One off and then on again.
Yes: Power the unit off and try step 5 with another black/photo cartridge. If the error persists with the new cartridge, proceed to Contacting Lexmark.
No: Continue to step 6.
6
Power the AIO on, reinsert the color cartridge, and close the top cover. Power the All-In-One off and then on again.
Yes: Power the unit off and try step 6 with another color cartridge. If the error persists with the new cartridge, proceed to Contacting Lexmark.
No: Try printing a test page. If the test page prints, the error is resolved
SOURCE: I have a Kodak ESP
If this printer is like some of the HP printers I have serviced in the past, many printers like this use a tiny bit of color as a "primer" to make the black "blacker" and to prevent bleeding in systems where the color is dye and the black is pigment.
A number of printers may allow a "use black only" in the driver settings, but many other printers will simply refuse to print if the color runs out, even if you are printing black and white.
The short answer is, chances are, you need to replace the color cartridge.
SOURCE: after replacing the color cartridge,
You have a bad cartridge. They have chips in them. Return it.
