I saw an ebay similar model for sale, that apparently has the instructions inside the box cover, but not a separate manual. That may be all that is available for you, even though the 8903 is a different model than yours. https://www.ebay.com/itm/Vintage-Ridgway...I searched for a manual using https://www.google.com and did not see one.
https://www.ebay.com/itm/Vintage-Ridgways-Lettering-Set-50-8903-Complete-in-Original-Metal-Box-Japan-/252640931864
You can't post conmments that contain an email address.
Depends on your machine, but remember if your machine has a 5mm needleplate opening, that limits the size of the lettering you will be able to produce. Unfortunately, to get larger output, you would need to upgrade to an embroidery machine or do the lettering manually with a satin stitch. You can, after practicing, do monogramming free hand with your machine and a satin stitch. However, remember, if the stitch width is limited, even satin stitch will still be limited by that stitch width.
How to Monogram with Basic Sewing Machine (be sure to use a stabilizer behind the fabric. Layer the fabric, then stabilizer, and put in an upside-down embroidery hoop--that way the fabric will be on the top and everything will be flat against the machine's sewing surface. )
How To Do Free Hand Machine Embroidery
(in this video, she puts the stabilizer on the top of the fabric, but it is wash-away stabilizer. If using a tear-away or permanent stabilizer, be sure to put it under the fabric.)
I recently purchased craftsman lettering tempate set 70709 at an auction. The operating instructions are in the box. I can scan and email to you. Only 2 pages.
This is called convergence. If the TV has auto convergence or 'Flash Focus', run it. All projection TVs have customer controls for minor adjustment. Give it a go with the menu or the remote convergence controls. If not, this is a common adjustment made by a technician on a house call. If the error is really big, say the colours are curved or you can see clear separate letters and things, you will need the convergence repaired. Get a quote - Usually about $300- $600 in home service.
1. From the start menu, Click on Run then type “dxdiag” 2. Click on the “More Help” Tab then click the “Override Refresh Rate” Button. 3. Set the refresh rate override value to 60
Hi there!
Right click on your mouse and go to screen resolutions and set the screen resolutions to your desired. Need to play around bits... find the right setting just click apply and saved.
I searched for a manual usinghttps://www.google.com and did not see one.
