Computers & Internet Logo
brian king Posted on Apr 24, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Sphere reversing camera not working. - Computers & Internet
Philip Morand
Level 2:
Sergeant:
  • Expert 205 Answers
  • Posted on Apr 24, 2019
Philip Morand
Expert
Level 2:
Sergeant:
Answers
205
Questions
Helped
82625
Points
549
Check camera power input from backup light circuit. Should be 12VDC when in reverse. https://www.6ya.com/callphilipforhelp
1helpful
How do you measure a ball shape
hi Phyllis.
this link will tell you how.
How to Calculate the Volume of Sphere
if you need more help go to this link.
How do you measure ball shape Google Search
2answers
How many 1 inch balls will a 10 inch sphere hold?
volume of 10" sphere is 1000 ties that of a 1" sphere (volume scales as the cube of linear dimension). The close packed fill-factor for spheres is 0.74 (see eg http://en.wikipedia.org/wiki/Close-packing_of_spheres). Thus you will get LESS THAN 740 1" spheres into a 10" sphere (quick calculation neglecting edge effects, which is why 740 is only a bound, not the actual number)
5.August.2014
What is the volume of the largest sphere that can be made inside the cube whose volume is 216m3?
Side of the cube = cube root of 216m3
= 6m
The maximum size sphere will have the diameter equal to side of the cube.
Hence the diameter of the sphere = 6m
Radius of the sphere = 3m
Volume of sphere = (4/3)x 3.142 x cube of the radius
= (4/3)x 3.142 x cube of 3m
Volume of the sphere = 113.0973355m3 = 113.097m3
- sonsunny
How do I determine the open space in a 12" cube
Determine the volume of the cube
Which is calculated by:
length x width x depth
then subtract the volume of the sphere's
Number of spheres multiplied by (4/3) * pi * radius3
To figure out how many sphere's you can fit in the cube
Divide the width of the cube by the diameter of the sphere then cube that number
(try it with a larger diameter sphere for example 6" sphere and sketch it out, you will see why)
0.01" Sphere-Total Volume
12"/0.01"=1200
1200^3 = 1.728 E 9 = Number of sphere's in the cube
1.728 E 9 x (4/3) * pi * 0.0053=904.32 cubic inches
Volume of Cube = 1728
Remaining Volume = 1728-904.32 = 823.68
You should be able to figure out how to do the other one.
DAR482BLS does not chill
Your black sphere is called a compressor .
The only way to know if this compressor is bad is by using a amp meter .
When compressor hum put your amp meter and see what the amp draw .
If you get a high reading it's bad .You can also try using a 3in 1 kit and see if it help the compressor
1helpful
Sphere Webcam,(sl-6820) 350k Pixel wont install
1st You download Webcam Driver.
After this install the Webcam driver in the system.
Installation of Webcam Driver
Go to the control panel
Click on the System Icon
Click on the Hardware Tab
Click on the Device Manager s
Select the Unknown Device or printer device where yellow Question Marks sign on it.
Right click on it and uninstall it.
After this go to the top of the device manager and click on scan for hardware changes.
Driver installation Wizard start.
Brows Your Driver from the Hard Disk and click on next.
Driver will be install.
Web camera Logitech Quick Cam Sphere AF
Thank you very much, the problem solved yesterday succesfully.
Logitech Quickcam Sphere
Try uninstall both software and hardware,After that connect the camera and install the software,I hope it works for u.
Regards,
Sandeep SIngh
Webcam
Yes the logitech sphere is mac supported, you can view and buy from here if you require one:- http://www.amazon.co.uk/Logitech-961310-0914-Quickcam-Sphere-Webcam/dp/B0000CFGON
Grand Canyon Tech
Grand Canyon Tech
