20 Most Recent Danby DAR482BLS Compact Refrigerator Questions & Answers
DAR482BLS does not chill
Your black sphere is called a compressor .
The only way to know if this compressor is bad is by using a amp meter .
When compressor hum put your amp meter and see what the amp draw .
If you get a high reading it's bad .You can also try using a 3in 1 kit and see if it help the compressor
5/27/2017 4:36:12 PM • Danby DAR482BLS... • Answered on May 27, 2017
My Danby Refrigerator Model DAR482BLS will not start is there a Start switch to make it run
You have just about figured this out . The starter is the problem in all likeliness. If it don't work, neither will any thing else.
2/4/2013 1:28:30 AM • Danby DAR482BLS... • Answered on Feb 04, 2013
Light comes on but refrigerator is not cooling.
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
ee
9/30/2010 11:27:11 PM • Danby DAR482BLS... • Answered on Sep 30, 2010
Turns on...clicks every few minutes....never gets cold
It looks like the compresor is trying to start and goes off on overload ,it could be a bad relay or a bad compresor.Try first replacing the relay located on the side of the compresor under a black plastic cover(ALWAYS UNPLUGGED THE FRIDGE BEFORE DO ANY WORK) if that does not work you need to replace the compresor.
4/9/2009 7:22:55 AM • Danby DAR482BLS... • Answered on Apr 09, 2009
Continues to freeze
It sounds like the temp sensor isn't working properly and letting the compressor run all the time till it freezes. If you are "handy" you can replace the temp sensor. Parts are available online at different websites like repairclinic.com or partselect.com, etc.
2/27/2007 3:07:20 AM • Danby DAR482BLS... • Answered on Feb 27, 2007
2answers
Danby DAR044A6LDB Mini Fridge. Where are the condenser coils on it please?
The two lines entering/exiting the lower right of the attached photo (back view) should be the condenser as the lines on left side appear to be for evaporation. Looks like they buried the coils inside the right side panel and possibly the top. The coils may be bonded to panel metal and the metal is what radiates extracted heat.11_8_2023_10_32_25_pm.jpg
11/8/2023 11:00:45 PM • Danby... • Answered on Nov 08, 2023
Danby Chest freezer leaking
No it is time for a new one. There is either a leak on the inner liner or the insulation between the inner layer and outer layer has broken down and is causing condensation.
9/13/2023 6:48:18 PM • Danby... • Answered on Sep 13, 2023
Danby Mini Wine Fridge runs but doesn't cool
8/8/2023 9:04:08 AM • Danby... • Answered on Aug 08, 2023
3answers
Danby DBC514BLS-1 beverage frig not cooling
If your Danby DBC514BLS-1 beverage fridge is not cooling and you have noticed frost on the back coil, it could be a sign of a problem with the fridge's defrost system. Here are some steps you can try to troubleshoot the issue:
  1. Check the fan to see if it is running. If the fan is not running, it may be a problem with the fan motor or the control board.
  2. Check the defrost timer and thermostat. The defrost timer controls the defrost cycle, and the thermostat monitors the temperature inside the fridge. If either of these components is faulty, it could cause the fridge to frost up.
  3. Check the wiring and connections. Make sure all the wires are securely connected and that there are no loose or frayed wires.
it is possible to replace the fan in your model of fridge, If you decide to attempt the repair yourself, you will need to purchase the correct replacement fan for your fridge and have the necessary tools to make the repair.
6/14/2023 7:12:01 AM • Danby... • Answered on Jun 14, 2023
My Danby fridge model DFF100C2BSSDD, the bottom shelf vegetables keep freezing and noticed some frost at the vents on upper shelf.
Increase the temperature inside by turning the knob anticlockwise. Put a thermometer in the fridge, it should be 3 or 4 degrees Centigrade. https://www.google.com/search?q=Danby+fridge+model+DFF100C2BSSDD+too+cold ..
1/11/2023 11:02:32 PM • Danby... • Answered on Jan 11, 2023
I have a refrigerator Danby DFF100C2BSSDD , it is normal but after a long periods ,it is too cold ,what is the problem
The most likely cause for the fridge becoming too cold after a period of time is an issue with the thermostat. Unfortunately, the thermostat for the Danby DFF100C2BSSDD is not easily accessible and will require a qualified technician to diagnose and repair.
1/7/2023 2:14:29 AM • Danby... • Answered on Jan 07, 2023
2answers
What are the power switches for on a Danby Beverage Center Model DBC514BLS-1
The power switches for a Danby Beverage Center Model DBC514BLS-1 are the power on/off switch and the temperature control switch. The power on/off switch turns the unit on or off and the temperature control switch allows you to adjust the temperature of the beverage center.
1/7/2023 1:44:53 AM • Danby... • Answered on Jan 07, 2023
I'm scraping a Danby propane refrigerator. Is there any safety concerns I should be worried about? If you have any tips I'd appreciate it
Propane is flamable but not Ozone damaging. Usually they are foilled with Cyclopentane, that is part of the Propane family but any refrigeration engineer will know what to do, if not look it up in the many training manuals.
5/8/2022 5:01:51 PM • Danby... • Answered on May 08, 2022
2answers
Danby fridge old model - freeze working but fridge section does not
Yes it has a fan you should here it and feel it. It sounds like your defrost coil may have gone out. Take the back pannel of the freezer off and see if it is clogged with frost.
3/5/2022 4:15:05 PM • Danby... • Answered on Mar 05, 2022
I have a Danby refrigerator and the water tray freezes up.
Turn the dial and make it a little warmer. It should be 4'C to 6'C. It is possible it needs a new thermostat if it is running all the time.
11/19/2021 5:57:47 PM • Danby... • Answered on Nov 19, 2021
I have a 1 and a half month old Danby all-fridge, and there is a smell like rotting flesh coming from it but not smell inside the fridge. ??if I need to find the water drip tray where is that located?
water drip tray is usually located under on on top the compressor? at bottom of fridge can pull out at front or back Check ice and water filter: If equipped, the Ice and Water filter in your refrigerator is responsible for removing any debris or contaminants from your water that may still remain after local water treatment. Most filters contain and are made up of carbon and fabric filter. Over time, the filter may become restricted and reduce the water flow to the ice maker, causing a symptom of little or no ice. Most manufacturers recommend replacing the filter every 6 months but local water conditions may require that you replace more frequently. Lastly a clogged drain line can cause a foul smell and get into the ice and water as we,,. drain fridge-drain-pan-undefined-undefined-0_0.jpg fridge back parts-undefined-undefined-2.jpg
8/14/2021 11:45:51 AM • Danby... • Answered on Aug 14, 2021
Danby DAR482BLS Compact Refrigerator Logo
16 questions posted
Top Danby Refrigerators Experts
vince
Are you a Danby Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
Danby Refrigerators
  • Danby Refrigerators
Most Popular Question
continues freeze
  • Refrigerators
