20 Most Recent
Logitech QuickCam Sphere Webcam Questions & Answers
Hi, I wonder if you
Try setting it to mirror to see the results. If it's good, then you know that the latest software is causing the problem.
7/28/2017 6:13:16 PM •
Logitech...
Answered
on Jul 28, 2017
When I plug my logitech "eyeball" webcam into the
Follow the instructions below and it will work.
Disconnect the Camera from the USB port and reinstall the CD or Downloaded software program.
When the program asks you to connect the camera to the USB port, do so and it should work.
Then to use it on the Web, do this.
Web Camera's have to be setup on the program they are to be used with. Just installing the
camera on your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order for the Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype
http://www.skype.com/intl/en-gb/download/skype/windows/beta/downloading/
set it up as follows:
Go to Tools, then Options, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
Then click on the Video Settings.
The camera, if Installed Properly, it will come up and show a video picture.
Then, on the bottom of the page click save.
The camera and audio should function properly. Your friends and Family will now be able to see and hear you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger
http://www.soft32.com/download_30.HTML
Go to Messenger at the top left and click on it.
Next go down to Preferences and click on it.
Next Calling and Devices on the right and set the Microphone and Speakers to the computer Audio Card.
Next go to the Test Audio section and (in blue writing) click on "Open the call setup assistant" and follow the instructions on the left window.
C. Windows Live Messenger:
http://download.live.com/Messenger
After you start Windows Live Messenger, expand the view by clicking on the square on top left next to the red X.
Then on the Windows Live messenger window on the right side, click on " "Show Menus." And then click on "Show the Menu Bar".
Next go to the Menu Bar on right side, click on " "Action."
Go to "TOOLS" and click "Audio and Video Setting" and follow the instructions.
NOTE: Your audio and video should work. Enjoy.
When done both the Audio and Video will function properly so you can chat and see family or friends you are connected to.
D. AIM (AOL) Messenger:
http://dashboard.aim.com/aim
On the VIM sign-in window click on Edit.
Then click on Settings Enhanced IM.
Next click on Enhanced IM.
Then click on Audio Video.
The Audio and Video portion has drop downs so you can select the proper audio card and video camera installed in you computer.
The Audi Video drop downs are
Microphone
Speaker
Camera
The audio and camera should function now.
Additional information to use with VIM settings.
Adjust Your Audio and Video Settings:
In order to adjust your audio and video settings, please follow the steps given below:
1. Click the Audio and Video Settings button directly below the My Buddy or My Camera window. If you are currently
Participating in an AOL Live Video IM session, a message will display: You must disconnect the current AOL Live Video IM
Conversation before running setup. Would you like to disconnect now? Click the Yes button.
2. The Audio and Video Tuning Wizard will appear to help you verify that your camera, speakers and microphone are working
Properly. Follow the on-screen prompts.
Notes:
The first time you use AOL Live Video IM, a message will display: Would you like to first check your audio and video settings? Click the Yes button.
The Audio and Video Tuning Wizard will appear to help you verify that your camera, speakers and microphone are working properly.
images in AOL Live Video IM may appear reversed, or as a mirror image (text may appear backwards) when you look at your own camera feed or at the
Picture-in-picture (PIP) display.
After making the settings your ready for a chat and video talk with your Family and Friends.
Hope this helps. Bud
12/16/2010 9:46:44 PM •
Logitech...
Answered
on Dec 16, 2010
I had to format my
Yes, if you can tell me what the manufacture and model number is. Do this to get that info and let me know and I will try to help you further.
Copy this site and paste it in your web browser address bar and hit ENTER.
http://www.download32.com/webcam-diagnostics-d35065.html
to download the Camera Diagnostic Tool and run it to check out your camera and/or problem.
Be sure the camera is plugged into the USB port before running the program.
As you run the program, write down the info about the camera so you will know what model and who manufactured the camera you have
attached so you can get the proper software drivers for it.
11/27/2010 10:53:44 PM •
Logitech...
Answered
on Nov 27, 2010
My webcam keeps stopping
Logitech ?
It could be your support software - make sure you haven't lost Microsoft Directx
You need at least version 9
6/10/2010 3:34:33 PM •
Logitech...
Answered
on Jun 10, 2010
Zebronics webcam error 8007045a
Web Camera’s have to be setup on the program they are to be used with. Just installing the
A. Skype Setup:
B. Yahoo Setup:
Microphone
Speaker
Camera
Notes:
5/22/2010 6:48:02 PM •
Logitech...
Answered
on May 22, 2010
I'm having problems with the mic distorting, any
Go to Control Panel and Click on Sounds, Click on Audio, then Click on the Microphone. Then Click on the drop down and select
Camera Microphone or Headset.
Click OK and it should work. Laptops have built in micophones if on at the same time as the camera microphone will cause audio
to be give you static. Either shut off the internal mike or disable the camera mike and see if that helps.
Web Camera's have to be setup on the program they are to be used with. Just installing the camera on your computer does not set
A. Skype Setup:
After downloading and installing Skype (http://www.skype.com/intl/en-gb/download/skype/windows/beta/downloading/ )
B. Yahoo Setup:
After downloading and installing Yahoo Messenger (http://www.soft32.com/download_30.HTML )
on the left window.
http://www.microsoft.com/downloads/details.aspx?familyid=d78f2ff1-79ea-4066-8ba0-ddbed94864fc&displaylang=en
On the VIM sign-in window, click on Edit.
Microphone
Speaker
Camera
conversation before running setup. Would you like to disconnect now? Click the Yes button.
Notes:
After making the settings your ready for a chat and video talk with your Family and Friends. Hope this helps. Bud
2/28/2010 10:17:24 PM •
Logitech...
Answered
on Feb 28, 2010
Webcm giving error 8007045a
Copy this site and paste it in your browser ADDRESS
Bar and hit ENTER;
http://www.free-codecs.com/AMCap_download.htm
to download the Free AMCAP Video Capture Program.
AMCap v9.20
AMCap is a small yet fully functional video capture application compatible with Microsoft
DirectShow. It is based on the sample AMCap from the Microsoft DirectX 9 SDK. AMCap supports
still captures to BMP, JPEG and PNG formats and it remembers your Video Input, Video Standard
and Video size settings from previous session. It has some nice features like multi-monitoring support, zooming, aspect ratio and interlacing features.
program.
AMCap is a small and effective piece of software and definitely worth trying.
Hope this will help. Bud
11/3/2009 12:14:09 AM •
Logitech...
Answered
on Nov 03, 2009
Lost all sound
You can redownload the sound driver from your computers manufacturing site, example: dell.com, enetr model number and download, install sound/audio driver. Reboot and your good to go.
10/4/2009 11:47:24 PM •
Logitech...
Answered
on Oct 04, 2009
Windows Startup with a blank screen after quickcam software
Hmm. It seems as if the driver isnt compatible with your hard ware! (sounds very stupid i know) This could be your graphics processor, motherboard,web cam or simply a combination of all three. Id recommend seeing if you can get hold of quickcam software from another vendor.(Just to ensure its not the software version.
If that doesnt work them im pretty sure that your laptop will not support it.
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=33739&lc=en&dlc=en&cc=us&os=228&product=92994
Sorry to be so blunt. If you have the time maybe you could try a fresh install then install quick cam first. If it still goes black screen it wasnt meant to be.
9/2/2009 11:59:39 PM •
Logitech...
Answered
on Sep 02, 2009
