Two clips hold the top on they are located in the gap between the top and the front. insert a knife in between the top and front on each side while maintaining a little upward pressure on the top. the top will lift up from the front. The top will hinge on two clips in the back of the top. Once you pivot up the top you will be accessing you lid closed switch which is located in the top of the machine good luck.
