20 Most Recent LG WM-2277HW Front Load Washer Questions & Answers
A DE Error Code is indicative of a “Door Error”. This indicates that the washing machine door is not shutting, locking or opening. This means that there is something faulty with the door switch and locking mechanism . You should get this replaced or you may have water where you do not want it. biigg53566
LG WM-2277HW... | Answered on Aug 13, 2018
Change the filter alone u will receive the better result.
LG WM-2277HW... | Answered on Feb 18, 2018
My guess is replace the drain pump. Inexpensive part but kinda hard to get to. Check out repair videos on parts sites or YouTube
LG WM-2277HW... | Answered on Jan 31, 2018
Easiest start is to take the top off and check for leaks maybe using a flashlight. Top comes off by removing a couple of screws in back, the sliding it rearward about 3 inches and then lifting up. Good luck. Report back what you find. Use comments.
LG WM-2277HW... | Answered on Jan 25, 2018
Switch to powdered detergent. You'll be much happier in the long run. Liquid detergent leaves a residue. Eventually the residue mildews. Powered detergent leaves no residue. Plus you will solve your current issue. Also skip the softener and use plain white vinegar in its place. The vinegar helps eliminate mildew and it also helps release Dey from your clothes in the rinse cycle.
LG WM-2277HW... | Answered on Jan 07, 2018
Suggest try same again.
Modern appliances have a zillion circuit connections of which any one of them can develop a "bug".
Unless it is under warranty it's usually less trouble and cost to simply replace it.
LG WM-2277HW... | Answered on Jan 02, 2018
"IE" is an error code that indicates a water inlet problem on an LG washing machine. This code will appear if the washer is not filled to the correct level within eight minutes after switching it on. Possible causes for the IE code include partially closed taps, improperly attached inlet hoses or clogged inlet hose filters.
LG WM-2277HW... | Answered on Dec 28, 2017
Disconnect the LG front load washer power cord from the wall outlet. Turn off the water supply to the washer at the water spigots coming from the wall.
Pull the washer 3 feet away from the wall, and disconnect the water supply hoses from the water inlet valve ports on the back of the washer. You may need a pair of channel lock pliers to loosen the hose connections.
Remove the screws securing the back of the top panel to the back of the washer with a Phillips-head screwdriver. Depending upon your model, you will have either two or four screws to remove.
Lift the back of the top panel up, and slide the top panel toward the rear wall, which will unhook the top panel from the clips securing the panel in the front of the washer. Lift the top panel off the washer and out of your working area.
LG WM-2277HW... | Answered on Dec 27, 2017
Sounds like the bearing or the belt pulley
LG WM-2277HW... | Answered on Dec 25, 2017
Your water supply may have a high sulphur content.
I tried a solution I found elsewhere - worked great. I had turned my drum enough to cause the display to turn on (a glitch in their program, I think), then I got the LE code on the next cycle.
Unplug for 10 minutes. Turn back on and press the Rinse & Spin button, then set Spin Speed to No Spin. Run this cycle, which should work fine. Afterwards, you should be able to run your machine as normal. If this doesn't work, replacing the Hall sensor would be the next step.
LG WM-2277HW... | Answered on Nov 28, 2017
that's a bad thermisitor the code is tE that's a lower case t and a capital E part number 6322FR2046C it's down at the bottom of the tub to the right of the heater.go here to see part
https://www.searspartsdirect.com/part-number/6322FR2046C/0026/795.html?modelNumber=WM2277HW&categoryName=Residential%20Washers&brandName=LG
LG WM-2277HW... | Answered on Nov 11, 2017
Need model # and specify what light.
LG WM-2277HW... | Answered on Nov 04, 2017
cheaper to check for a problem in the impeller first as the pump motor seldom fail but there are problems with items jamming the impeller
LG WM-2277HW... | Answered on Oct 29, 2017
Replace the bad thermistor. Costs about $6. Not that hard to do. Check out repair videos at repairclinic.com. Or appliancepartspros.com
LG WM-2277HW... | Answered on Oct 09, 2017
Did you check to see if the hot and cold are hooked up backwards? Try switching them.
LG WM-2277HW... | Answered on Sep 23, 2017
The hose from the soap drawer to the tub may be split. These hose have flexible ridges and its common for them to split inside one of the ridges.
LG WM-2277HW... | Answered on Sep 17, 2017
loose wires connection or pc board
LG WM-2277HW... | Answered on Aug 26, 2017
LG WM-2277HW Front Load Washer Logo
2,568 questions posted
Top LG Washing Machines Experts
Marvin
Marvin
jimorris77
Paul
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
WM LG
  • WM LG
Most Popular Question
stop old water smell earthy odour in lg
  • Washing Machines
