SOURCE: where is the serial number on canon pixma mx310?
The serial number is located inside the maching, behind the tape attached to the cartridge carrier. When the cartridges are all the way to the left side (position for changing cartridges), the serial number is visible at the center-right position. Open the maching as if you were going to change cartridges.
SOURCE: I changed my Canon PIXMA MP780 3e cartridge, and
I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink or toner cartridge?
Please consider the following:
If you are using a refilled (the absolute worst possible choice) or third party cartridges (2nd. Worst possible choice) that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks or toner causing problems with print quality or damaging the physical printhead or photo conductors.
If you are using factory new ink or toner cartridges, then please call the manufacturer’s Technical Support for assistance with the warranty on the cartridges
Don
SOURCE: printer canon pixma IP1000 does not work on windows 7 64-bit
here are the windows 7 64 bt drivers
http://software.canon-europe.com/software/0035868_0010104.asp?model=
click
aomwin110ea24.exe
4070.33 Kb.
under the software label to the buttom if the page
via the canon web site submit a support request
https://www.canon.com.au/support/support-request-form
try looking also for printer manual as ti might explain printer jams
https://www.canon.com.au/support/printers?option=drivers&optionId=15BDBCAC1F5C49A39051698214EF4A90&source=PIXMA%20series&subcategory=AD739ABDF9174EE18729813BA7AE57B4
select actual printer you have
then download
then third tab across
manuals
Testimonial: "get canon support https://www.printersupportcentre.com/canon-printer-support.html"
